Thread: coolant leak from unknown part
Results 1 to 6 of 6
  1. #1 coolant leak from unknown part
    May 2013
    canada
    hey folks i need some help i have an 04 with a coolant leak that i have identified but i dont know what the part is. it is a small 90 degree tube that looks like it is going from just behind my idler pully into the head. what is this part, can i replace just this tube???? pls help
  2. #2 Re: coolant leak from unknown part
    SWPA
    Probably coolant elbow.
    Look for the write ups, its easy.
  3. #3 Re: coolant leak from unknown part
    You have to pull the alternator bracket to change it
  4. #4 Re: coolant leak from unknown part
    Dorman 47065 plastic or 47065HP aluminum.
  5. #5 Re: coolant leak from unknown part
    Pennsylvania, USA
    Go aluminum, peace of mind. Be careful installing them though, Bill actually pointed out in another thread that if you use too much force with the aluminum ones, it is possible to crack the timing cover.
  6. #6 Re: coolant leak from unknown part
    Apr 2013
    White Lake
    Its quite easy and you should do it instead of taking it to a shop. I actually just did mine because the top elbow cracked and leaked coolant EVERYWHERE! Your going to have to take your belt off, unbolt the alternator which is a few bolts then the bracket that goes from alternator to the engine also take off the heater core mount thing which is 3, 15mm bolts. Its like 7 total bolts to take off everything so it should take you no more than an hour to fix it. If your plastics break off inside the holes do not worry because you can take a screwdriver and pull them out thats what I did but make sure you get all the pieces out!. I bought new plastic elbows which were $3.99 at autozone. "Part Number: 47065" Make sure you slide them into the heater core first then slide them into the engine slowly then take the 3, 15mm bolts and start putting them in equally to make sure its slides in correctly.
    Hope this helps, Also I found a few youtube videos on this problem that happens quite often.
    P.S. Make sure you but the belt on right!!!
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. Unknown Coolant Leak
    By hihosilver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2012, 07:01 PM
  3. What part is this? (Anti-Freeze Leak)
    By Bologna in forum General Tech Discussion
    Last Post: 12-21-2011, 08:03 PM
  4. Oil in my coolant? LIM? Need part numbers and what is best to get....
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2011, 01:13 AM
  5. Weird Part and a coolant leak from it
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 05:42 PM
