Thread: oscillating RPMs
Results 1 to 11 of 11
  1. #1 oscillating RPMs
    Jan 2012
    FT Campbell, KY
    Last night I removed my TB and cleaned that massive buildup of carbon. At the same time, I replaced the MAF. I was hoping that the surging/lugging and oscillating RPMs would be cured...only to be disappointed. What else should I be looking at? I'm also getting really horrible MPG to the tune of 12-17mpg.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  2. #2 Re: oscillating RPMs
    Vacuum leak?
  3. #3 Re: oscillating RPMs
    Jan 2009
    Tallahassee, FL
    Did you keep the screen in the TB?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: oscillating RPMs
    Jan 2012
    FT Campbell, KY
    no vacuum leak that I can detect. I did the "ether test" where you spray TB cleaner or such like around the vacuum lines and detect an audible surge. No such luck.
    yes, the screen is still installed on the TB.
    Colleen
  5. #5 Re: oscillating RPMs
    Jan 2009
    Tallahassee, FL
    Connectors on the sensors good? If any are loose, etc the car won't be real happy.
    77 Morris Garage B
  6. #6 Re: oscillating RPMs
    Jan 2012
    FT Campbell, KY
    when I put the car back together, I confirmed good connections were made. I'm not convinced a dirty K&N would cause these symptoms, but the oil will be dry and ready today. Other than the cone, what else could I be missing?
    Colleen
  7. #7 Re: oscillating RPMs
    Jan 2012
    FT Campbell, KY
    Good news is that my MPGs seem to have improved drastically. I got back to 90mi on 1/4 tank consumed. I'll be sure to get a more-accurate MPG when I refuel. The car is still oscillating about 3-400 RPMs while at idle.
    Colleen
  8. #8 Re: oscillating RPMs
    Unplug the IAC and see what happens.
  9. #9 Re: oscillating RPMs
    Jan 2012
    FT Campbell, KY
    Replaced the IAC and that did nothing different. The old one was well-coated in carbon build-up, so it's not EXACTLY a waste of money. There's only one other sensor on the TB, so now to go and look that thing up.
    Colleen
  10. #10 Re: oscillating RPMs
    Pennsylvania, USA
    Is your MAP sensor sealing? It was the source of my random rpm surges. Sometimes people either forget to replace the o-ring on the PCV valve located underneath it, or it can deteriorate. My actual MAP sensor gasket (the ribbed one) was dry rotted and torn, giving me a sporadic vacuum leak depending on the temps outside/in the engine bay.
  11. #11 Re: oscillating RPMs
    Jan 2012
    FT Campbell, KY
    I was kind of leaning towards MAP now...admittedly simply because that's the only thing left in the throttle body to replace and I'm busy throwing money at the problem. Thanks for your help, yall.
    Colleen
  1. No RPMs..?
    By GTBabyGirl in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2011, 07:46 PM
  2. Rpms on the highway?????
    By nickdemio in forum General Tech Discussion
    Last Post: 05-13-2011, 12:27 AM
  3. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  4. jumping rpms
    By 99GP3800GT in forum General Tech Discussion
    Last Post: 03-17-2010, 12:49 AM
  5. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
