Dude put 93 in it
Dude put 93 in it
Not if he's mentioning seeing knock. It's the same concept of guys adding some race fuel when there at the track to eliminate knock. A good portion of those guys didn't tune for race gas...
Didn't realize he was na. I guess it didn't matter much then
My 2006 gt saw 6-7* stock. After 605s 180 stat, intake and overkill PCM I have seen 1.1* on wot pulls. And for some reason 4* if I'm climbing a steep hill as it seems to bog in 4th. I added 110 race gas ( 4 gallons) to a full tank and it has read 0.0 ever since.
a incar tune overkill should be abble to make it run with 0 knock specially with 91 octanne, i was running a 2.5'' downpipe and he made it run with 0 knock.
a fendwerwall intake would be better for a n/a, any cold air we can get the better. I am on a hai setup atm and i have noticed the lack of power when setting at a light for a min or 2.. switching back to my cai soon.
It may be strange but running an opencone in my GTP I was getting 5-6* of KR, switched to a fenderwell intake and now I'm only getting 2-4*.
Maybe when my headers and 1.9's go on I can get rid of all of it.
I'm guessing the best CAI is in the fender well? Seems like the thrasher and wizaird are nice but overpriced. My Bonneville had a fwi from intense and my intake temps were almost always on ambient temps. My hai ( just a cone off the maf ( 04+) is usually 30-50* higher than ambient
U realize its maybe $2-$3 morefor the premium per fill up , right? And yes its important you use at least 91 ( in general ) your tune is based off what octane you have in the car during the tune
i have a peak of .5* of knock at shift
I built mine from light duty pvc pipe from lowes. Cost me $17 + $22 for the filter. I also insulated the piping to help shield out heat. The intake air is normally within 1* of outside air.
