Thread: Blew tops of pistons
Page 6 of 6 FirstFirst ... 456
Results 101 to 112 of 112
  1. #101 Re: Blew tops of pistons
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Do you guys have any ideas on how to het them to stop leaking? Idk why but I can't get them to sit right. I feel like there in all the way but when I spray carb cleaner a couple bubble still
  2. #102 Re: Blew tops of pistons
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    You'll have to replace the lower o rings. Best bet to replace both upper and lower of course just for insurance.
    When you put it all back together though use some kind of lubricant to get them to slide in whether it be silicone spray or grease. Silicone is what I use especially if the seals are rubber because petroleum products will eat the rubber over time. So don't use engine oil to lube them up.
    They'll never sit properly if they're dry.
  3. #103 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Alright ill give it another try when I'm off. Also does that seem right that it would bubble if there where a leak there. My ltfts changed from 16.4 to 11.1 and back up when I sprayed around.
  4. #104 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Alright so i tried new o rings and nothing. But now when i drive it will go to negative 3.2 then when i let off back up to 16.4. I tried ressetting the battery to start fresh and nothing. Any ideas?
  5. #105 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Computer is probably just trying to relearn all of the trims now that you reset everything.
  6. #106 Re: Blew tops of pistons
    Dec 2011
    Decatur
    O well it still shows 16.4 though. I sprayed carb cleaner on my injector and got it down to 3 but it goes right back up
  7. #107 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Any ideas on why its going from -3.2 while driving then 16.4 while idle. I think its something with the injectors cause when I spray it'll go down to 4 at idle but I've tried changing o rings and nothing
  8. #108 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Anyone?
  9. #109 Re: Blew tops of pistons
    Dec 2011
    Decatur
    So I changed my uim gasket and put new oil on the super. When I fired it up it smoked like crazy then quit. My car now runs rich -22 when cruising and still lean sometimes but not as bad. If I give it some gas it goes to zero. What could cause it to do this I only changed that one gasket. Could it be my maf sensor cause when I unplugged it car ran the same. Please help.
  10. #110 Re: Blew tops of pistons
    May 2013
    Central IL
    Have you found out the problem my ltfts are doing the same thing?
  11. #111 Re: Blew tops of pistons
    Dec 2011
    Decatur
    No I'm still messing with the piece haha its a headache forsure.
  12. #112 Re: Blew tops of pistons
    Dec 2011
    Decatur
    After a little while the ltfts drop down to like 12 at idle. Also blower oil seems to be leaking but its not leaking out where it can be seen.
  1. 1986 Grand Prix w/ factory T Tops
    By GP007 in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 04:27 PM
  2. Blew it up :(
    By shawn3091 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:01 PM
  3. Burnt fluid in a trans with only 3k tops on it???
    By Kejross in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2010, 09:06 PM
  4. blew up Gp AGAIN
    By kaosGP97 in forum The Rant Forum
    Last Post: 08-04-2009, 10:10 PM
  5. air bag blew up!!!
    Last Post: 07-19-2008, 03:35 PM
