Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 12 of 22 FirstFirst ... 21011121314 ... LastLast
Results 221 to 240 of 438
  1. #221 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sounds boring
    L76 springs and LS1 retainers.
  2. #222 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2009
    Tallahassee, FL
    Yea it'll be boring lol. Just anything so I can beat on this car again, I can't even really go into boost without the car throwing a fit, makes a hell of a racket for a couple of days till she calms down again. I just need something that runs right for now.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #223 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    you dont want boost then
  4. #224 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2009
    Tallahassee, FL
    To late, I'm already addicted lol
    Anything to hear the btch whine again
    77 Morris Garage B
  5. #225 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2009
    Tallahassee, FL
    The one question I forgot to ask: will the L26 flexplate work out fine with my torque converter?
    77 Morris Garage B
  6. #226 Re: Top Swap Info and Faqs, Also lots of 3800 Info
  7. #227 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2009
    Tallahassee, FL
    Gotchya, I wasn't sure if the torque converters were different or not
    77 Morris Garage B
  8. #228 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    they are.
    but newer plates are dual pattern?
  9. #229 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Slight question, I am about to do a Top swap, I've got a guy, willing to sell me those parts (They comes from a '98 GTP, my GT is a 2000, everything should fit?):
    -Heads from SC motor
    -Harmonic Balancer From the SC motor
    -Tensioner for SC belt
    -Idlers for Sc belt
    -Coil Pack Bracket
    -Lower Intake Manifold from the SC motor
    -Fuel Rail
    -Fuel Injectors
    -Supercharger
    -Supercharger Belt
    -Throttle Body from SC motor
    Is there everything?
    Then I plan on getting the Gasket kit on ZZP (Emailed them so they add the rocker bolts to it for convenience) , S/C oil, 180 Thermostat, AL104.
    A overkilled pcm tune for the top swap.
    And then get the coolant, oil, filters locally.
    I have my mech ready to do everything with me. So I took the OP infos, was there all the torque specs?
    And now I just saw something about the MAP Sensor, do I need to change it, or will my L36 Map sensor work fine after the top swap?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  10. #230 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    things you should do right away so you dont have to do it later: ARP head and rocker bolts. seriously.
    a tune from a local specific to your car would be best if you can find someone.
    you need the L67 map sensor. it is 2 bar map, which youll need so your PCM can read boost.
  11. #231 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    but then you'll have to use an L67 bin.
  12. #232 Re: Top Swap Info and Faqs, Also lots of 3800 Info
  13. #233 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    indeed.
    Was injector connectors an 01+ only thing?
  14. #234 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Ohio
    umm i think. i know impala l36 connectors are the different ones. mine on the 99 are ev6
  15. #235 Re: Top Swap Info and Faqs, Also lots of 3800 Info
  16. #236 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Ohio
    yeah i think 97-03 grand pirxs are all good. its the other cars with l36's that have the problems
  17. #237 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    No.
    My 2002 had multec's, had to throw on some HV1's.
    Its either 2000+ or 2001+ L36 cars.
  18. #238 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Ohio
    hmm not sure then.
  19. #239 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    Hmmm so is therr a problem with the injectors? And for the map, is the one on zzp good to go? Oh and will the l36 maf work with the top swap?
    Ps: these cars rock in snow and ice, the handling is perfect, didn't even feel that snowstorm I was in for 150km.
  20. #240 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    you'll wanna use L67 injectors, connectors migth be different.
    L36 MAF works, but again you'll want to use the L67 TB.
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
