Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 5 of 22 FirstFirst ... 3456715 ... LastLast
Results 81 to 100 of 438
  1. #81 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    morad doesnt give "deals", but he is a good source to find parts specifically for our cars. find someone taking parts off their car and selling it for next to nothing. patience is the key.
  2. #82 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Quote Originally Posted by Bryan921SS View Post
    Ed quoted me $1100 for all the hard parts...plus shipping.
    The labor would be murder if you take it to a shop though.
    $1100? What all did you get a motor along with it? I thought it was more along the lines of $600-$700
  3. #83 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jersey
    $1100? I paid that for my gen5 top swap parts...
    16' wrx sti- stock
  4. #84 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Yeah, that sounds about right. As Ed's business has grown, his prices have gone up. Service can't be beat, and if you need something right away, he probably has it. If you can wait, you can usually do much better on the forums.
    2001 Buick Regal LS - Almost Stock
  5. #85 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Maybe I've just been around too long to know about this inflation bullsh*t LOL
  6. #86 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Riverdale, Ga
    Hello. I have a 97 Pontiac grand prix, and the a/c only works on the highest setting. i have tried replacing the resistor pack, but that didn't solve my problem. i went as far as hooking my battery up to a test light to bypass the electrical send from the car it self, and all fan speeds worked fine, but that's only with the battery sending direct power to the a/c switch. can someone please help me?
  7. #87 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Dude, this is the top swap section...post it in another thread.
  8. #88 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Hoffman/Schaumburg, IL
    Quote Originally Posted by 99prixgt View Post
    He has an 04+, I'd bet that Ed quoted him for the Gen V stuff so he doesn't have to go around tring to find a DBW throttle body to GeN 3 adapter
  9. #89 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    on the parts list does it matter yrs like i gott 2000 gt but does it matter what yr parts are? or they jus gotta come from gtp in some form or way?
  10. #90 Re: Top Swap Info and Faqs, Also lots of 3800 Info
  11. #91 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2009
    br
    get 98+ parts. the 97 has a crappy vacuum tree setup.
    alrighty thanks and if you can find some of these parts brand new is it better to ge them new or is junkyard decent way to go?
  12. #92 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Charles City, IA
    Look in the for sale section.
    SMGPFC Two Nipple General
  13. #93 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    brand new? thats all kinds of doubtful since they dont make this motor anymore. used are fine so long as they are in good condition.
  14. #94 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2009
    br
    this is what ed quoted me is this good or no?
    Ok. We sell the hard parts which include:
    heads
    valve covers
    lower intake manifold
    injectors
    fuel rail
    supercharger
    TB (no maf)
    vac lines
    idler pullies
    brackets
    balancer
    For $650 You will also need wiring upgrade, gaskets/torque to yeild bolts, and Custom PCM.
    I can get you the wiring upgrade for $40 and GM gaskets and tty bolts for $245.
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  15. #95 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jersey
    Quote Originally Posted by bballa0740 View Post
    heads
    valve covers
    injectors
    fuel rail
    supercharger
    TB (no maf)
    vac lines
    idler pullies
    brackets
    balancer
    you will also need...
    -coolant
    -$100 for head gaskets
    -11qts of oil and 2 filters(1 to use to wash down lifter valley) (4.5qts to change with right away) (another 4.5qts to change in 500-1k miles)
    -pcm tune (unless you have a tuner) I run a top-swap tune from Intense, it cost $200
    While your at it, you might as well get new ls7 lifters as well. Paceperformance has them for an awesome price.
    The only wiring upgrade you need is a Map sensor adapter.
    As far as cylinder heads, get the 98 and up style ones. The 97's crack around the valves (some say it doesn't matter but, if im paying all that money i don't want to put on cracked cylinder heads)
    It would be wise for you to get your cylinder heads machined, fluxed, and checked for cracks. That cost me $190 but its well worth your investment.
    16' wrx sti- stock
  16. #96 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2009
    br
    -coolant
    thanks whats ls7 lifters? andim lookin around 1400 not even installed that sucks but i wana do it you said you run a top swap tune fron intense you got a mail order one from them that you can use after top swap?
  17. #97 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Wausau, WI
    they are lifters from out of the LS7 V8 GM motor......
  18. #98 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    wiring upgrade?
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  19. #99 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Wausau, WI
    I guess...
  20. #100 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Kluke's Avatar
    Michigan
    I have a 2004 gt and my friend offered me a very good price on a super charger from a 98 would i be able to make this work?
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
