Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 22 of 22 FirstFirst ... 12202122
Results 421 to 438 of 438
  1. #421 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    What about the l67 swap kit do I need that boost bypass valve solenoid wire
  2. #422 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    you dont, its likely not a active code in your pcm, or a na one in general.
    what you could do is find a gtp pcm of the same year as your car is. its a gp na right? and use that. it might toss a code for the bbv actuator or not. my regal didnt when i took it off mine for a while.
    re use your maf if the donor engine's maf is not the same part#.
    only issue with the gtp pcm is your vin wont match if you have inspection. and you need to do a security learn to make it crank and fire up. key to run 3 times for 10 minutes, off each time for less then 5 seconds. but a battery charger while you do this, and dont open the doors or power anything inside. radio, windows ect. turn that all off and dont use anything.
    or call zzp and tell them your set up and give em your vin#. get a 1.0 if you plan to stay stock ish.
  3. #423 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    I believe that this is what I need
  4. #424 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Quote Originally Posted by andesmint View Post
    So, i got a little confused with the vac routing. Mainly because I was referencing this
    I was confused because the write up said to connect the top of the BBV to the "tree" an the bottom should see atmosphere, but didn't mention anything about the SC bypass solenoid. Because of this I didn't know if i was suppose to run a line from the lower BBV nipple to the solenoid and have one of the nipples on the solenoid seeing atmosphere or if i should delete the solenoid and just have the bottom nipple on the BBV see atmosphere. After asking Snowth1ef I learned the the SC bypass solenoid should be deleted and that it is in fact the lower nipple on the BBV that must see atmosphere.
    In order to possibly help others I modified the above diagram so that it showed the correct vac routing for a topswaped 3800
    Right on
  5. #425 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2015
    Columbus, OH
    It will get you going. I'd still get something to scan for knock.
    Top Swapped 01 Imp
  6. #426 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Looking to buy another scan gauge but I ordered 2 zzp pcm they played me on the black Friday sale stated starting of at 62.5 total was 236 after 10%discount gp pcm had a 75 fee for l67 engine and transmission map mc was straight forward no fees but it's all gud
  7. #427 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Will still delete the solenoid
  8. #428 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
  9. #429 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    thats a dead fuel pump, nothing shot out the sharader valve, it should hit the cars hood. id toss a tester gauge on it. to be sure.
  10. #430 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Right on bro will look into that in the morning
  11. #431 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Swapped out the fuel pump with a new one fuel shoots to the hood after depressurize but still same issue but car runs better can notice on acceleration with new pimp
  12. #432 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    the maf might be bad. try unplugging it then crank it. see if it fires up. might run like crap but it should fire up.
  13. #433 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Right on I will been doing a look research and might b the iac
  14. #434 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    its also possible, but when my iac went bad it would fire up if i touched the gas pedal.
  15. #435 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member kimpossibull's Avatar
    Aug 2021
    California
    OMG- amazing ! I am not going to be doing a TOPSWAP for the record. I began reading this thread bcuz it said all kinds of info for the 3800 s/c. I couldnt stop reading--until i finished all 22 pages. This was incredible. Now i need to find a thread that actally talks about my cars problem. I'm hoping I find will a discussion that has input from the author of this thread. I'm not an engine wizard or strong enough sometimes to perform car tasks but I love learning about my car and trying to do the maintenance. Thanks again for this thread.
  16. #436 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by kimpossibull View Post
    start a thread on the problem. theres some dam good knowledge here
    08 grand prix NA3800
  17. #437 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    got to love someone whos willing to search around for a issue then find other threads and get locked into them lol
    if you dont find your issue post away asking never hurt. at least we know you looked first
  18. #438 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Dec 2022
    Charlotte
    I just did a top swap on my grand pri 05 GT, everything is working well, but I'm using a pcm SC and I can't use the TC, so in the cluster the TC OFF light turns on, any way the light doesn't turn on? My pcm is already programmed with Hptuners
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
