K thanks man
K thanks man
Most prefer the lower compression l67 block so they can run more boost. . Also the higher compression is less forgiving when it comes to tuning. . What goals are you trying to reach? . Most combinations have been done before...
and intercooled XPZ build will easily run on an L36 block. on an L67 block you might run out of pulley and timing to be had if you push it hard whereas the L36 might have slightly more headroom to grow.
hardly seems worth it when you could do a turbo for the same price. http://zzperformance.com/3800/l36-supercharger-kit.html they might just sel th elim still, iirc it was 300 bucks alone. someone had one for sale not to long ago, no idea if it sold or not.
Do the fuel lines from the l36 set up clip into the fuel rail for the l67 just fine? Or do I need some kind of adapter?
I have a 99 with the quick release style fittings. They swapped out perfect. Like Scotty said the bends will be off a little but that's not a big deal, just be fragile with them.
Sent from my LG-H901 using Tapatalk
Nothing needed, your stock lines will hook-up. The fitting feels kinda janky, loose, but I ran it that way for 4 years. I have -an line now, but still using the quick connect fittings. I'll eventually get rid of the quick connect fittings because when you have them on and off a lot like me, they will leak and need new o-rings.
Ok got the motor and transmission in swap out my 99 gt motor and transmission from a Bonneville l67 00-05 01 gtp transmission car runs but it feels like supercharger is not working didn't but the zzp l67 swap kit remapped the map sensor to the front and the evap sensor just the boost bypass valve isn't connected snipped the connector from the junkyard wanted to know if I gave it a ground and power would it work wasn't trying to order zzp kit but I see there's plugs into the pcm pin 77
What pcm or tuner are you running?
you cant drive that on your old stock na pcm and na tranny gears. you need a tune for this swap or you'll blow it all up. tranny and the engine. way to much timing. kr city, injector data wrong, trans gears are wrong with a host of other settings.......park it asap. get a tune.
