Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 13 of 22 FirstFirst ... 31112131415 ... LastLast
Results 241 to 260 of 438
  1. #241 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Yeah I'm getting the tb and the injectors. But will 98 inject work with 00?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #242 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    they should but double check the electrical connectors are the same.
  3. #243 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    If they don't fit is therr anything I can do? Because leaving the prix unworking in my mech harage wouldn't be the best.
  4. #244 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    get HV1 connectors and install them
  5. #245 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    Are they available at local shop or only online? Because if they aren't 100% needed it'd be an uneeded expense if I was to order them rights away, are you positive that the 98 inj will need it to install on my 00?
  6. #246 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    I'm saying go look at your injector connectors.
    Take a picture if you want.
    Then we can tell you 100%.
    I'm suggesting this because I'm no longer sure and my source for this piece of information has since changed their site to exclude this information.
  7. #247 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    It ain't dismantled yet, so I doubt I can take pictures of them. I'd rather, have everything right, so I can only pass a weekend with it in the garage.
  8. #248 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    pop the engine cover off and check. im fairly certain it was only 01+ but theres only one way to be sure
  9. #249 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    Excuse the newbishness here, but, where would be the location of the injectors? I don't have the plastic cover on the engine anyway, straight up with the L36 upper manifold intake.
    And I think I've read somewhere that 01+ had those injector connectors. But before, didn't have them. But worth to check before everything.
    Also for the MAP Sensor, would a L67 one chopped off work, or just get one from ZZP? So Easy Performance - L67 Swap Kit #11-01-00687 this kit or Easy Performance - L67 Map Sensor Plug #10-01-00686 the simple wires?
    Sorry for all the questions, but afterall, somewhere in the OP it states to check for the most infos we can before doing anything! We have to begin at some point somewhere.
  10. #250 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    on the top of the plastic manifold there is a metal tube which is your fuel rail. follow this down to to three black plastic tubes. those are your injectors.
    they have an electrical connector on them. this is what im referring to as the injector connector.
    google image hv1 injector to see what they look like. if theyre the same as what you have youre fine.
    for the map, either will work. however if you dont get the clip for the bbv solenoid, traction control will have to be disabled either in your tune of turning off the switch all of the time or rewiring it so its off by default.
  11. #251 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    I had better pictures, but it seems like my cellphone didn't bother saving them, but on this one, I seem to have one injector : http://img267.imageshack.us/img267/5...0116415522.jpg
    They seem to have the connectors on them, does this mean the 98 injectors won't fit or will they? And urgg, winter, makes my engine bay looks messy while it is always super clean.
    And what about the bbv solenoid clip? Where can I get that, I like having traction control for cold/wet/slippery days.
  12. #252 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    yeah those are hv1. 98 gtp injectors will work.
    id suggest buying the kit from zzp so you can maintain traction control.
  13. #253 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Ohio
    umm matt. 98 should be ev6?
  14. #254 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    ev6 is L32?
  15. #255 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    Easy Performance - L67 Swap Kit #11-01-00687 That would be the kit to keep traction control?
    Also, just for check up :
    Those are the hards parts I'm getting from the 98 GTP :
    Heads from SC motor
    Harmonic Balancer From the SC motor
    Tensioner for SC belt
    Idlers for Sc belt
    Coil Pack Bracket
    Lower Intake Manifold from the SC motor
    Fuel Rail
    Fuel Injectors
    Supercharger
    Supercharger Belt
    Throttle Body from SC motor(Doesn't have the MAF, so keeping my GT Maf, been told it would work.)
    Anything missing?
    As for ZZP :
    Throttle Body Gasket
    Supercharger Gasket
    Lower intake Manifold Gaskets
    Valve Cover Gaskets
    Head Gaskets
    Rocker bolts
    Head Bolts
    Supercharger Oil
    Autolite 104 Spark Plugs
    Colder Thermostat, 180*
    Easy performance MAP Sensor
    Anything missing there?
    I've also talked to will about the tune up for the top swap, everything's good there. I'll get a Overkilled pcm.
  16. #256 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Dstratt01's Avatar
    Jan 2012
    New Haven, Indiana, United States
    i read through all of the parts on the parts list and cant quite make sense of what is needed. I have a 97 gt and just bought an l67 tonight. i will be doing a to swap soon and am wondering ( aside from the complete l67) what parts i will need. thanks for any input.
  17. #257 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Québec
    I have quite the complete list of needed part above your post, I think at least. Which is why I posted it here, wanting to know if I had every parts listed down, because I am about to part out everything out of a GTP.
  18. #258 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2011
    Tallahassee
    Great writeup. I'm starting my research and am about to try to pull off this mod. I've got a 2000 GT and pick n pull has a 97 GTP that I'm going to salvage from. Just read the entire discussion and can't wait to get started. Thanks again everybody.
  19. #259 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2011
    Tally, FL
    Is it okay to install my 42lb injectors on my car now or wait till i install the supercharger? Would there be any drawbacks?
  20. #260 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Out West
    without a tune you'd be running incredibly rich.
    Whine with your Cheese?
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
