Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 10 of 22 FirstFirst ... 8910111220 ... LastLast
Results 181 to 200 of 438
  1. #181 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member 02PrixGT's Avatar
    Canada
    or is that a bad idea?
  2. #182 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    because it wont run right and you need all the parts to make everything work together. we spelled it out for you in this thread why you need everything. 10 pages of reading is really not that much.
  3. #183 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Willoughby, Ohio
    reading is the only way you will learn about the car on the internet...obviously, so get to it!
  4. #184 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Hoffman/Schaumburg, IL
    Quote Originally Posted by CTKGP09 View Post
    Man, I never thought this would make 10 pages.....
  5. #185 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    I cant add to the original post (Too many Characters (25000 limit)) So here is my Update:
    Sorry this hasn't been updated in a while, but My trans has held up for almost 3 years in top swap form, and here is some additional info:
    Recomended Parts
    (These should be added to your parts list to make the Top-swap perfect)
    GTP Fuel Pump ( get the whole canister, as it also has a venturi pump...some wiring may be required)
    GTP Coils (They ARE different than GT coils, and it causes KR issues on some cars)
    Fuel Pump Rewire (this or a boost-a-pump, with the high compression you never want to risk a lean situation)
  6. #186 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    those are more for if you're going for a build.
    Another one is get the heads checked out...
    I'm curious about this fuel pump issue though... You mention in another thread that someone had KR issues till they swapped fuel pumps.
    Was the KR consistent or what?
  7. #187 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member bjermane1's Avatar
    Nesbit, MS
    Great Write Up! Read through the whole thing and not to sure of what everything is. Im planning on doing the top swap around tax season, and i was wondering is there any other write up with pictures or video? Thanks guys
    2004 Grand Prix GT - fwi, custom flowmaster exhaust, DHP PCM
    *Coming Soon* - 1.9 Roller Rockers, 105# Valve Springs, Top Swap (from gtp), Then dropping the pulley size
  8. #188 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jun 2010
    MN
    What exhaust pipes should I get?
    I have a 02 SE. The exhaust or whatever pipes are. Different from the gt, gtps.
    Ps yes I am a rookie at all this but I am tryna learn.
    That if you confess with your mouth, "Jesus is Lord," and believe in your heart that God raised him from the dead, you will be saved. - Romans 10:9
  9. #189 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    any headers are fine.
  10. #190 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    Subscribed!
    2001 Grand Prix GT
    3800,Open Cone, Tinted tails, 5% front tint, double 5% rears. Kenwood head unit, new subs-pending
  11. #191 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Dec 2010
    delaware
    hi..
    i have a 98 olds intrigue my friend and i did the whole top swap on... everything listed has been changed ive even have had the computer tune..i run in to a problem no everything is set up and plug in new battery and all we go to start the car and all it does is slowly crank.. only thing i can think of is that i might need a high torque starter.... please help need the car running before we get some nasty snow...dont feel like driving my camaro all winter :\
  12. #192 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Or perhaps you need spark and fuel?
    Start a new thread on the topic in the general section.
  13. #193 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Wausau, WI
    Quote Originally Posted by bjermane1 View Post
    There is a video of doing a lower intake manifold gasket change.... this will be a good general starting point but the vehicle this is being performed on is a SC'ed car so it will not show you everything you need to change over, but it is a good thing to watch to become familiar with some more of the parts and where they go....
  14. #194 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Nesbit, MS
    Quote Originally Posted by liquifire View Post
    there is a video of doing a lower intake manifold gasket change.... This will be a good general starting point but the vehicle this is being performed on is a sc'ed car so it will not show you everything you need to change over, but it is a good thing to watch to become familiar with some more of the parts and where they go....
    thank you sir
  15. #195 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member ray4was's Avatar
    Buffalo, New York
    So if i wanted to supercharge my stock gt with the L26 i would need heads off a L32 sc motor to do a top swap. I read the top swap thread like 50 times i just want to make sure im understanding it. Thanks
  16. #196 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    ill quote what i wrote you in your thread:
    in short, no, you can use L67 components but you'll need to keep your throttle body and returnless fuel lines.
    everything else should work (pulleys, heads, lower intake, blower, etc.).
  17. #197 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    When I was getting my parts out of the junk yard I had wondered about the fuel pump since it was multi-speed. I know there is a relay in the u/h box for it. Looking at the wiring diagrams though, I couldn't tell how or if the wiring were any different between the two. Because of the relay, I would have to assume there is one, I just didn't see it.
  18. #198 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Tuned 2 F's Avatar
    Jul 2010
    Cburg VA
    I have a base 2006 Grand Prix. I've read through all 10 pages and read about the top swap over and over again.
    I have 86,000 miles, probably about 90k before I'll be able to afford to do a top swap.
    To my understanding, all I have read about so far in this thread is 04 and older. From what has been said, it is 100% certain that a series 3 can be swapped safely? I'm fairly certain there's no major differences, from 04-06 I should worry about with doing a top swap.
    Should I contact Ed Morad for parts, or would buying most of the parts from ZZP be a good idea. My cart for ZZP is pushing $2500 :0
  19. #199 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Quote Originally Posted by Tuned 2 F View Post
    You should go to a junkyard and pull the parts yourself so that way you get an idea on how it comes apart and have a smaller chance of screwing up on your car...plus it would be alot less than $2500
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  20. #200 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2011
    sudbury
    this is what i have to mess with . i have a 2000 gt and i wanna put a 97 gtp supercharge on it (top swap). Questions!!! people tell me to do a top swap and slap a gtp pcm in it with an 97 gtp front harness because the 2000 GT harness isent the same. but wat about the tranny gearing ratio. isent the gt pcm tunned for a gt tranny and a gtp pcm tunned for a gtp tranny. people tell me that the gtp pcm will work with a GT tranny.... is this true? i was gonna throw the whole 1997 GTP motor and tranny in the 2000 gt with the gtp wireing and pcm, thats alot of work. but then i heard that the fuel pump needs to be a 2 stage for a superchager (gtp) if i swap the whole engine, which means i have to run a whole nother gas line from back to front... and with a top swap i dont need to do that sapossably.... im totally confused on what to do now...
    All i know is i have a complete 2000 Grand prix GT that runs mint ( my car)
    and that i have a complete 1997 Grand prix GTP car ( rotten Frame) for parts. soo i have all wires fuel pumps engine, tranny, and all . i need to know exacly the best situation to do.
    I have NO WAY to tune my PCM where im located... soo thats out of the question. anyone have pointers. no one wants to help my situation and i posted quite a few topics. let me know guys... thanks
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
