Thread: High idle?
Results 1 to 16 of 16
  1. #1 High idle?
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Hi guys
    I find my car (3800 na) will idle high most of the time. When you first start it cold it stays up around 1500rpm for a few mins, then goes down under 1000. Once warmed up and in drive it's usually in the 800rpm range but when put in park it will usually jump to just under 1000rpm. I am going by the idle in other v6's I have had (3.1L) and this one seems kind of high. My throttle body and idle air control valve has been cleaned really well recentlly so that shouldn't be the problem. Any info is appreciated.
    Thanks.
  2. #2 Re: High idle?
    Oklahoma
    The Idle Air Control motor still could be bad or not responding properly to PCM input. One way to tell for sure would be if you had a scan tool and look at the IAC. Another way would be, if you have another GM V6 around, to swap it out with the IAC from one of them and see if that makes any difference.
    I guess it could be your MAF sensor too if its dirty, so you might get some electronics parts cleaner and clean that up and see if that helps.
    One other possibility and Ive seen them do this before, but not as frequently on a GP. Your Throttle position sensor could have a dead spot in it or weak one right around the idle position. However, it is typical for a TPS to cause shifting issues too. But if the idle issue were the result of a developing dead spot rather than a completely failing TPS I dont know if we would see the shifting issues.
    Hope this helps out. Oh, be sure your air filter is clean too. If the engine is struggling to get air its going to raise the idle some in order to get what it needs.
  3. #3 Re: High idle?
    May 2008
    Ontario
    Thank's for the info. I have a spare idle air control motor in my toolbox so I will try swapping that out. I have electronics cleaner as well. I was going to clean the maf before but thought the cleaner might damage it. The air filter is not new but not terrible, I will probably get a K&N soon, that's why I have not replaced that yet. Maybe there is a bad spot in the tps though too because sometimes it seems like it misses a bit durring highway driving so I will try to get a hold of one of those to try as well.
  4. #4 Re: High idle?
    Jersey
    Quote Originally Posted by WhiteGT View Post
    Hi guys
    I find my car (3800 na) will idle high most of the time. When you first start it cold it stays up around 1500rpm for a few mins, then goes down under 1000. Once warmed up and in drive it's usually in the 8000rpm range but when put in park it will usually jump to just under 1000rpm. I am going by the idle in other v6's I have had (3.1L) and this one seems kind of high. My throttle body and idle air control valve has been cleaned really well recentlly so that shouldn't be the problem. Any info is appreciated.
    Thanks.
    What?!?!?!?!
    16' wrx sti- stock
  5. #5 Re: High idle?
    May 2008
    Ontario
    I cleaned the maf sensor and the air temp sensor while I was at it with the electronics cleaner. I also took the idle air control out and worked it in and out all the way with intake cleaner and it seemed to move alot smoother so hopefully this helps. I think I will pick up a K&N drop in too since the air filter has seen better days.
  6. #6 Re: High idle?
    Feb 2008
    Quote Originally Posted by 99prixgt View Post
    What?!?!?!?!
    I think he meant 800 RPM
  7. #7 Re: High idle?
    May 2008
    Ontario
    Quote Originally Posted by DanGTP View Post
    Thanks, my mistake.
  8. #8 Re: High idle?
    May 2008
    Ontario
    So after trying those things, it still idles the same. Maybe that's normal for these cars. What do other peoples cars idle at?
  9. #9 Re: High idle?
    Barksdale AFB, LA
    After warming up and reaching operating temp, with it in park or neutral, ac compressor off, mine idles about 650RPM. Add 100 RPM if the ac compressor is on.
    2009 Subaru Impreza WRX STI
  10. #10 Re: High idle?
    May 2008
    Ontario
    Quote Originally Posted by Sabrewings View Post
    See mine is around 800rpm and up in those same conditions. That's why I am thinking something is a bit off. When I put it into park after driving it usually jumps up to around 1000rpm's and drops in between 800-1000rpm's. When I let it idle, it does stumble slightlly as well. I have scanned the car a few times at the garage I used to work at but it never shows anything.
  11. #11 Re: High idle?
    Barksdale AFB, LA
    All 3800s have the slight stumble at idle.
    What are you using to get your RPMs? Your dash? The needle may not be perfectly calibrated.
  12. #12 Re: High idle?
    May 2008
    Ontario
    Mainly the dash, but I have also checked it with a snap on scanner and I know it was higher than it said it should have been. I will hook it up again this week if I get a chance for a more accurate reading.
  13. #13 Re: High idle?
    Nov 2008
    Tucson AZ
    Hi guys
    Thanks.
    Did you fix the problem if so what was it?
  14. #14 Re: High idle?
    Way to go...thread is going on a year old...
  15. #15 Re: High idle?
    Wausau, WI
    usually a high idle is attributed to a vacuum leak somewhere....not always, but probably 80% of the time or more.
  16. #16 Re: High idle?
    Nov 2008
    Tucson AZ
    I think its better to search old treads and try and find your answer instead of creating new ones so people can answer the same questions over and over.
    I just wish people would come and add a post when they fix the problem it can really someone else out. I think that is what forums are for to help each other out.
  1. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  2. stalling and bad idle.....
    By kingd44 in forum General Tech Discussion
    Last Post: 10-09-2008, 07:27 PM
  3. Idle issues.
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-02-2008, 11:43 AM
  4. idle issues.
    By TDCRacing in forum PCM Tuning
    Last Post: 09-01-2008, 02:21 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
