I was wondering since I have a auto trans fluid leak from the cooler lines if i can simply replace just the connectors, as rockauto sells them individually or if i should replace the whole line. From what I would imagine, it is the connectors and their O-rings which appear to be the weak links in this setup. But I did want to seek out advice on the forum about this or recommendations, thanks!!
