Thread: Engine Build
Results 1 to 16 of 16
  1. #1 Engine Build
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    ST3 Cam
    130# springs
    Modded Retainers
    JP Double Roller Set
    Ported Heads (On the edge about not sure)
    Should I also get pushrods, and valves? My GT has 72k on her. Im thinking of just getting the internals done with.
    Recommended Pushrod sizing?
  2. #2 Re: Engine Build
    Oklahoma
    I think you will need a double roller chain with those valve springs if Im not badly mistaken and there are possibly some modifications needed to the double roller timing chain gear depending on which one you get. I would think that with that kind of added stress on the valve train, stronger push rods would be a fantastic idea.
    As for size and whether or not you should get new valves, Im not sure.
  3. #3 Re: Engine Build
    Nov 2008
    NY
    No your right i forgot to add that lol Im getting a JP double roller with no tensioner
  4. #4 Re: Engine Build
    Oklahoma
    I dont recall if the JP double roller had the chamfer (sp?) issue or not, but it would be worth looking into.
  5. #5 Re: Engine Build
    Nov 2008
    NY
    Yea they have the same warning for both the JP and Rollmasters. I guess the sp issue is for Double Rollers kits on some cars. They say throw another gasket/spacer on there.
  6. #6 Re: Engine Build
    Oklahoma
    My understanding is that if you have the Chamfer corrected that no longer is necessary.
  7. #7 Re: Engine Build
    Nov 2008
    NY
    hmm could you explain a little if possible?
  8. #8 Re: Engine Build
    Oklahoma
    The bottom gear that the chain rides on, the side of it that butts up against the crankshaft, the chamfer is wrong and and causes the chain to stick out further than it should causing the chain to ride at a slight angle to the top gear which puts stress on the chain and causes it the rub up against the oil pump housing. Now I dont know if this applies to the JP double rollers or just the Rollmaster Double Roller chain.
    Correcting the chamfer prevents the rubbing and clearance issues along with allowing the chain to roll in line with the top gear. The double rollers out there, whether both the JP or Rollmaster Im not sure, were made for the Australlian 3800 which has a bit different crank than the American version.
  9. #9 Re: Engine Build
    Nov 2008
    NY
    ah I see I didn't know what you were saying was wrong with the chamfer. Thank you for that I did not figure in the angle of the chains to the cam. Hmm ill ask tim or zoomer over at zzp if that applies to both. Thank you Scotty! First day here and I'm already being informed haha
  10. #10 Re: Engine Build
    Bastard Reptile's Avatar
    Kansas City, MO
    Gaskets won't prevent this from happening. Machine the gear so that it sits correctly on the crank, trust me on this one.
  11. #11 Re: Engine Build
    Nov 2008
    NY
    Oh Wow That's Eye opening
  12. #12 Re: Engine Build
    GT Level Member TurboKent's Avatar
    Woodward, OK
    lol i like the cd in the back ground "one million of the worlds best recipes"
    2003 Grand Prix turbo intercooled
  13. #13 Re: Engine Build
    Kansas City, MO
    Quote Originally Posted by TurboKent View Post
    haha....THAT has some interesting recipes on it for sure.
  14. #14 Re: Engine Build
    Jul 2008
    Germantown, Maryland
    dang....... one million????? How do you even look through them all!
  15. #15 Re: Engine Build
    Oklahoma
    I think he should be sharing them.
  16. #16 Re: Engine Build
    Jul 2008
    ^ agreed... what kind of Alfredo Dishes are on there????
  1. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  2. * VID of motor build *
    By RED GTX in forum Off Topic Discussion
    Last Post: 07-19-2008, 09:13 AM
  3. SQ Build... the begining
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2008, 07:28 PM
  4. build in progress
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 06-11-2008, 07:09 PM
  5. First wash after the new build.
    By Biggie in forum Visual/Body Modifications
    Last Post: 05-10-2008, 09:32 AM
