Thread: 91 octane benefits in N/A 3800?
Results 1 to 20 of 27
  1. #1 91 octane benefits in N/A 3800?
    Aug 2012
    Nova Scotia
    Any mpg gains,power or performance gains?
  2. #2 Re: 91 octane benefits in N/A 3800?
    Florida
    I had the overkill 91 octane tune on my GT last year and it suppose to add some power but my car ran excellent with the tune plus I had full bolt ons.
  3. #3 Re: 91 octane benefits in N/A 3800?
    Jul 2012
    Chicago
    I feel like my car is a little more spunky when it's running 93. Whether it's just a placebo effect or not, I've never been able to test.
    -Carl
  4. #4 Re: 91 octane benefits in N/A 3800?
    GTP Level Member
    springfield IL
    I've been running 93 for two tanks now... Does seem a lil more peppy. I just filled up today, the dic said I used 10.7 gallons but car only took 8.3 gallons... I would assume gas mileage is getting better
  5. #5 Re: 91 octane benefits in N/A 3800?
    Donating Users
    Oct 2012
    lake city,fl
    i run 93 in my 04 n/a all the time its a definite gain on mpg's
  6. #6 Re: 91 octane benefits in N/A 3800?
    GT Level Member Shiftingshaddow's Avatar
    KC
    i have the supercharger. i bought the car about 2 months ago from a girl who used 87. it ran like a champ. i put 93 in it (the two stations i can find anything higher than 91) and runs the same as far as I can tell. same mpg. i've put 4 or 5 tanks in it now and used seafoam in the first tank. i can't tell any difference.
    maybe i'm just lucky, though.
    i put 91 in my 89 regal 3.1L. made no difference at all.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  7. #7 Re: 91 octane benefits in N/A 3800?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I have a incar tune from overkill for 91 octane for almost 2 years now, best mod I have done so far, better mpg way more power and compliments my other mods
    For all you n/a guy's without a tune running on 91 it wasting your money,.
    And for the supercharged guy I hope you know you HAVE TO run atleast 91.
  8. #8 Re: 91 octane benefits in N/A 3800?
    It really depends on the car. The 04+ cars definately benefit from it because they had a lot of extra timing and would knock easily on 87. Using higher octane reduces some of the knock and gives you more power.
  9. #9 Re: 91 octane benefits in N/A 3800?
    St Thomas Ontario
    04+ n/ a cars make the same power as 03 under I thought. I researched some sites and they say they make the same hp
    Wouldn't be the first time the interwebs was wrong though
  10. #10 Re: 91 octane benefits in N/A 3800?
    Jul 2012
    Chicago
    When I filled up last friday I put in a tank of 93. I just filled up this morning and got 18.6 MPG vs the basement 17's I normally get. My driving style didn't change at all from normal, in fact there were probably a couple of extra WOT pulls in there to see if the high octane made a difference. I wonder if it's a coincidence.
    -Carl
  11. #11 Re: 91 octane benefits in N/A 3800?
    Last edited by matt5112; 03-28-2013 at 08:29 AM. Reason: because we had it last week.
  12. #12 Re: 91 octane benefits in N/A 3800?
    KC
    Quote Originally Posted by Grimsin View Post
    yeah. i know. i was saying previous owner ran it on 87. it seems to have little or no effect. she apparantly wasn't hot rodding it around.
  13. #13 Re: 91 octane benefits in N/A 3800?
    Florida
    I always run 93 octane in the Gtp. Always.
  14. #14 Re: 91 octane benefits in N/A 3800?
    Howell, NJ
    Depending on the amount of ethanol content in the fuel (its different everywhere), A higher octane rating can decrease your gas mileage.
  15. #15 Re: 91 octane benefits in N/A 3800?
    May 2008
    Winnipeg, MB
    I thought the car needed to be tuned for higher then 87 octane fuel if its n/a.
    2007 Pontiac Grand Prix
  16. #16 Re: 91 octane benefits in N/A 3800?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    ^^^ Nope. I run 90 in my NA all the time and have been totally fine. Seems to be better for it IMO
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  17. #17 Re: 91 octane benefits in N/A 3800?
    gardner,mass
    Quote Originally Posted by Shiftingshaddow View Post
    i got my 04 from the dealer and immediatly noticed it has 87 in it when i test drove, i went to the gas station and filled up with 93 cus it was basicly empty and as i was driving(my dad was in the car and heard it too) you could hear and feel the 93 kicking in. The car started running so much smoother and had more of a roar to it.
    Our pcms sense what octane gas we are burning and run accordingly unless obv tuned otherwise. So you would def see gains from 93, i would try a tune up, replace pvc clean maf wire plugs fuel filter air filter ect.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  18. #18 Re: 91 octane benefits in N/A 3800?
    How do you hear higher octane?
  19. #19 Re: 91 octane benefits in N/A 3800?
    I didn't say 04 made more power than 03, at least not on paper. My point was that GM put more timing in the cruising areas. This means that you can potentially have knock easier in those areas. Knock reduces power output by lowering timing to reduce knock and save the engine. A higher octane does not knock as easily, therefore the timing isn't reduced and the motor can using the additional timing and that equates to more power vs the lower octane fuel. This is subjective to the question... is the motor seeing KR?
  20. #20 Re: 91 octane benefits in N/A 3800?
    Apr 2012
    Goderich, Ontario
    Couldn't agree more.
    -Paul Walker
  1. 91 octane fuel in a N/a 3800 good or bad?
    By thomasd2010 in forum General Grand Prix Discussion
    Last Post: 03-16-2013, 12:59 PM
  2. Benefits of ant EGR delete ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 05-27-2012, 05:39 PM
  3. Naturally aspirated benefits with high octane gas?
    By DBGP in forum General Tech Discussion
    Last Post: 11-29-2009, 10:12 PM
  4. benefits of blocked egr?
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-12-2009, 04:03 PM
  5. ? benefits of intake?
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 05:18 PM
