Thread: 3800 Series 2 N/A under-drive pulleys?
Results 1 to 7 of 7
  1. #1 3800 Series 2 N/A under-drive pulleys?
    Feb 2013
    Houston
    would they free up noticeable power? the trans has 144 thousand miles, texas highway miles by middle aged couple. unsure of vehicle history so im cautious of any powertrain upgrades. i cant seem to find good info in these topics regarding the Series 2 N/A... this other site, 3800pro.com has so little trafic on its forum, it takes weeks for someone to respond to a post. my longtime forum houston-imports.com has crazy traffic. go there. lol.
  2. #2 Re: 3800 Series 2 N/A under-drive pulleys?
    Florida
    I had the water pump underdrive pulley and the alternator one even though I never installed the alternator one on my old GT and i did notice a lil something.The car revved a bit faster and had slight more pull towards mid range,top end. But they arent really worth the cost. Id say skip them or if you wanted to find a used water pump one.
  3. #3 Re: 3800 Series 2 N/A under-drive pulleys?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    underdriving a water pump is silly
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  4. #4 Re: 3800 Series 2 N/A under-drive pulleys?
    Feb 2013
    Houston
    Quote Originally Posted by Seachicken View Post
    reason? different rpm affects water transfer?
  5. #5 Re: 3800 Series 2 N/A under-drive pulleys?
    Jan 2013
    Edmonton, Alberta
    you reduce the pumps output at all rpms, for minamal gains
  6. #6 Re: 3800 Series 2 N/A under-drive pulleys?
    Feb 2013
    Houston
    i can heed that because i live in Houston and we dont have Summer so much as we have Broil. its not hot like Nevada, its jungle-nut-sweat-humidity heat.
  7. #7 Re: 3800 Series 2 N/A under-drive pulleys?
    Pennsylvania, USA
    An intake will give you more power than any under drive pulley.
  1. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  2. 3800 Series III L26
    By michael152354 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 01:09 AM
  3. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  4. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
