Thread: Air Cleaner Check Valve
Results 1 to 10 of 10
  1. #1 Air Cleaner Check Valve
    Jul 2012
    Buffalo, NY
    Hey guys,
    I have been running a check engine code on my '08 Grand Prix. 3.8L.
    The code was P0411: Secondary Air Injector Incorrect Flow.
    I replaced the Smog Pump (electric air injection reaction pump) as was told by many people. That was Saturday.
    I then cleared the code with my code scanner. Monday my check engine light came back on running the same code. I checked all the hoses to make sure they were connected, and then cleared it again. Then today, the light came back on again with the same code. The guy at advanced auto said the only thing he can think of is it being the Air Cleaner Check Valve, which is a very expensive part. For starters, where is that located on the engine? and does anybody know if that is what could be what it is? and if there was a way to test it to fix the problem rather than replacing it? or what other things it may be? or if there is possibly a way to bypass it so that it doesn't run the code, and will still pass NYS inspection.
    Any help is greatly appreciated.
    Thanks
    Jake
  2. #2 Re: Air Cleaner Check Valve
    Pennsylvania
    Checked the fuse?
  3. #3 Re: Air Cleaner Check Valve
    Jul 2012
    Buffalo, NY
    Where is the fuse located?
  4. #4 Re: Air Cleaner Check Valve
    Pennsylvania
    Fusebox, I'd assume.
  5. #5 Re: Air Cleaner Check Valve
    Pennsylvania
    If the hoses aren't the problem, the pump's not the problem, the fuse isn't the problem, the relay isn't the problem, then perhaps you'll need to check the wiring for a short - perhaps it's rubbed somewhere.
  6. #6 Re: Air Cleaner Check Valve
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i would check the valve on the back side of the motor and make sure it is working if the pump has been replace and it is running it will be the valve on the back stuck closed Graphic.gifbe on the end of the hose off the pump
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  7. #7 Re: Air Cleaner Check Valve
    Apr 2009
    Elkhart
    i would check the valve on the back side of the motor and make sure it is working if the pump has been replace and it is running it will be the valve on the back stuck closed Graphic.gifbe on the end of the hose off the pump by num 2 in pic hope that helps
  8. #8 Re: Air Cleaner Check Valve
    Jul 2012
    Buffalo, NY
    I checked the fuse today, and it is good. Where is the relay located for the air pump?
  9. #9 Re: Air Cleaner Check Valve
    Pennsylvania
    It should be labelled on the lid of the fusebox. I'm spitballing there, because I don't have one of these pumps.
  10. #10 Re: Air Cleaner Check Valve
    Jul 2012
    Buffalo, NY
    its not in the fusebox. i traced the wires from the check valve, and i think i found the right one, i just have to create a system for testing it, which i'll do this weekend. thanks for the help though!
  1. Air Injection Check Valve replacement
    By ajohnson2u in forum General Tech Discussion
    Last Post: 03-10-2012, 01:38 AM
  2. Is there a cleaner way to do this? (ghetto rig)
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-10-2011, 12:08 AM
  3. Oil pump check valve
    By CTRIDER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 10:11 PM
  4. how do i check my boost bypass valve?
    By bluevet03 in forum General Tech Discussion
    Last Post: 04-26-2010, 01:30 PM
  5. Engine Cleaner
    By JCG's-GTP in forum Detailing Tips and Tricks
    Last Post: 08-12-2009, 04:37 PM
