Thread: 2005 base model mod help
Results 1 to 16 of 16
  1. #1 2005 base model mod help
    SE Level Member MOTELETJR's Avatar
    Houston, Texas, United States
    I have a 2005 base model grand prix looking for max upgrades.. I curently have 2.5" pipe from stock cat, no res to a magnaflow exhaust. Custom intake and breather filter. 180" t-stat just did tune up. What else could i possibly do? Headers? top swap? or will that kill my tranny.. I have 105,000 miles.. Beginer looking for expert advice thanks..
  2. #2 Re: 2005 base model mod help
    04 Comp G.
  3. #3 Re: 2005 base model mod help
    GT Level Member GP Guy 07's Avatar
    Feb 2013
    Elgin
    Quote Originally Posted by MOTELETJR View Post
    Did you have it tuned for the 180 stat? if not it won't do you any good.Also building more power to a stock tranny spells breakage.Hopes this helps
    07 GP black on black,SPO spoiler,grills,hai,aftermarket rims,Led tails,drilled+slotted rotors
  4. #4 Re: 2005 base model mod help
    Thanks guys.. no i havent tuned yet.. i was waiting till i got all my upgrades the was going to purchase an overkill pcm.. Not sure how to tune myself or what scanner to purchase.. Is overkill the best pcm out there or zzp? Just ordered a powerlog for a little more power. Looking at a ported rear next..
  5. #5 Re: 2005 base model mod help
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    dont get ported rear one it flows fine, get a downpipe.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: 2005 base model mod help
    Feb 2013
    Elgin
    A HV3 for more top end helps on NA's.Overkill is what most guys use,seems to be the the norm.Sounds like you're in the right track.
  7. #7 Re: 2005 base model mod help
    ok powerlog on, next is downpipe and tuned pcm, are injectors and rockers only for s/c or will they help a n/a?
  8. #8 Re: 2005 base model mod help
    Injectors are not needed if staying N/A.
    Rockers might help with upper rpm flow, but I doubt you'd really notice alot.
  9. #9 Re: 2005 base model mod help
    is there really nothing else for low end torque?
  10. #10 Re: 2005 base model mod help
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    A supercharger
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  11. #11 Re: 2005 base model mod help
    I had that plan at first, but as I was reading into it a supercharger wont bolt on to my n/a engine L26. Or am i reading wrong? Will I have to change the tranny also? You guys are a big help thanks
  12. #12 Re: 2005 base model mod help
    Adding a supercharger is alot of work and huge headache 90% of the time. You'd have to swap the entire top end over from a supercharged motor. The heads, intake, blower, fuel rail, injectors, different pcm, the whole works. The trans wouldnt need to be touched.
    If you added a cam, that would help just about everywhere for power and a tune would help "some" aswell. The NA motor is just very limited.
  13. #13 Re: 2005 base model mod help
    Arizona
    Turbo or bust
  14. #14 Re: 2005 base model mod help
    Feb 2013
    Elgin
    I would keep it simple for now.
  15. #15 Re: 2005 base model mod help
    yea this is my dAILY DRIVER, so dont want to much damage..only 107,000 miles
  16. #16 Re: 2005 base model mod help
    Feb 2013
    Elgin
    Getting it to breathe easier helps.Rockers and injectors can be used on na also.
  1. Oem nav install in base model
    By carriaga89 in forum Audio, Security & Visual Electronics
    Last Post: 09-15-2017, 03:42 PM
  2. Base model vs GT
    By midrange in forum General Grand Prix Discussion
    Last Post: 02-16-2012, 01:35 PM
  3. My Girl's '06 Base Model
    By Swiggles in forum Members Rides
    Last Post: 12-02-2011, 04:38 PM
  4. 2005 - Base Model - Serpentine Belt Pattern Diagram
    By YMS1975 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-29-2011, 09:15 AM
  5. Base model in need of a Supercharger
    By imjustanobody34 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 12:07 PM
