Thread: catalytic converter
Results 1 to 2 of 2
  1. #1 catalytic converter
    Feb 2013
    St. Louis
    My 08 gp failed Missouri emissions inspection due to o2 sensors not reading the same, tech told me it's 90% likely replacing converter will solve this problem. My question is this: Is this a job I can do myself relatively easily? I've done basic auto maintenance (brake pads/calipers, changing starter, replace plugs, etc.) in the past but I'm no mechanic.
  2. #2 Re: catalytic converter
    Should only be 4 bolts. 2 at the manifold and 2 at the catback section. The cat is welded into a whole downpipe section.
    They might be tough to get off, but seeing how the car is only 5 years old and the state you live in, I'd say they'll still come off somewhat easy.
    I suggest you buy a quality cat converter and not a cheap highflow cat so you wont have this problem again.
  1. Catalytic Converter HELP!!!!!!
    By KickerGrandPrix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2012, 06:48 AM
  2. Catalytic Converter?
    By Lawenforcer in forum General Tech Discussion
    Last Post: 02-21-2012, 02:53 PM
  3. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  4. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
