Thread: 2006 Pontiac stalling driving down highway!
Results 1 to 9 of 9
  1. #1 2006 Pontiac stalling driving down highway!
    Jun 2012
    Mississippi
    My car has been acting up the last few months I will run 60-70mph down the highway and the car will just shut off at random. When it does the dash lights will flicker on and off several times and it will have trouble starting back up but normally does after the third or forth try.
    It's doing this randomly it will go for a few days without it happening and then all of the sudden it will shut off. Like this morning on my way to work 44 miles one way it shut off on me twice back to back but after that I was able to dive to work without a issue.
    I've recently put a new battery in it and I've also just replaced the crankshaft position sensor. Does this seem like a ground issue?
    Jun 2012
    Mississippi
    And it's not throwing a code
    Jun 2012
    Mississippi
    Anyone have a idea? I'm thinking about replacing the power and ground cables to start with and then if that's not it maybe a ignition problem?
  4. #4 Re: 2006 Pontiac stalling driving down highway!
    Well Clark... first thing I'd like to know is.. what are you driving, meaning which model please. (cause you have 2006 in the title)
    Sounds a lot like an ignition switch since you've already replaced the more common crank sensor.
  5. #5 Re: 2006 Pontiac stalling driving down highway!
    GT Level Member GMCustomerService's Avatar
    Michigan
    Vinson clark,
    I’m sorry you are experiencing this issue with your vehicle. This may be related to a ground issue; however, it is difficult to be sure.
    Have you had the vehicle inspected for this issue? If not, I recommend you consult with a certified technician for an official diagnosis.
    Please keep us posted.
    If you have additional questions, please feel free to contact me privately.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
    Jun 2012
    Mississippi
    Sorry 2006 pontiac Grand Prix naturally aspirated 3.8 it's just a 4 door sedan.
    Jun 2012
    Mississippi
    Quote Originally Posted by GMCustomerService View Post
    Vinson clark,
    Louis
    GM Customer Service
    I have not had the car inspected for this issue I'm thinking about carrying it to a gm dealership on Monday though because this has been a on going problem.
  8. #8 Re: 2006 Pontiac stalling driving down highway!
    Michigan
    Vinson clark,
    Please keep us posted. If you need additional assistance, please feel free to PM me with your information.
    I look forward to your reply.
    Louis
    GM Customer Service
  9. #9 Re: 2006 Pontiac stalling driving down highway!
    Buffalo NY
    Check the ignition fuse under the hood... my car was doing similar things.. it would shut off here and there.. turns out.. it was because the fuse was melting instead of blowing... because of the aftermarket amp and radio i had... i used the ignition wire for accessory power.. causing more draw from the ignition power line. I ended up melting part of the fuse box and having to replace the whole thing. It hasnt shut off since. Worth a shot..
  1. Question: Engine is cooling off to much on highway driving
    By michaelg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2012, 08:37 AM
  2. Was driving around aimlessly on the highway today.
    By Wakeboy1337 in forum Off Topic Discussion
    Last Post: 07-25-2011, 03:32 PM
  3. Low Coolant light during Highway driving only
    By davhamm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2011, 04:14 PM
  4. highway driving
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 07-14-2010, 10:35 PM
  5. Lost all my oil while driving on highway
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 05:16 PM
