Thread: Car cooling fans not working + overheating issues PLZ help.
Results 1 to 20 of 22
  1. #1 Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    My 04 GT is having some overheating issues. I have come down to the fact that its my cooling fans. They do not turn on. I have replaced Thermostat, Radiotor flush, and new Temp. sensor. Ive noticed today that my cooling fans are not turning on at all. When I turn the A/C on both fans turn on. When car is idling, and in traffic it overheats fast. When on highway car temp is fine. What to do? Help!
  2. #2 Re: Car cooling fans not working + overheating issues PLZ help.
    fan relay
  3. #3 Re: Car cooling fans not working + overheating issues PLZ help.
    How hot are we talking?
  4. #4 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    Im talking about overheating to the max
  5. #5 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    I replaced fan 1 relay, thermostat, temperature sensor, and did a radiator flush with new coolant. What else could it be?
  6. #6 Re: Car cooling fans not working + overheating issues PLZ help.
    Pennsylvania
    I opened up the fusebox and took it apart... was burnt behind the fan relay. Cleaned it and the fans work normal again. Maybe check for that.
  7. #7 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    now with the A/C on fans will turn on and off. I move relay a lil bit and the fans turn back on. Car overheats when at idle
  8. #8 Re: Car cooling fans not working + overheating issues PLZ help.
    I think you have more than 1 issue.
    If the cars cooling system is working correctly, the Thermostat should open and allow all the coolant to flow throughout the motor. It should never overheat if the coolant can flow like it should and the thermostat is working with no air in the system.
    90% of the time the fans should never even kick on because the cars thermostat is working correctly and not letting it get too warm.
    I think you have a ton of air trapped in the cooling system causing it to heat up quickly.
  9. #9 Re: Car cooling fans not working + overheating issues PLZ help.
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    -Assuming no fans and idling (little/no airflow) eventually that coolant is going to be heatsoaked and will cause an overheat.
    -When Cruising, the fans should never kick on because the airflow is good (assuming stock fan settings of ~220) When idling, once the fans come on, the gauge drops quickly.
    -Not sure exactly how fast he is heating up, but with my 04 even sitting in a drive thru i gain 15-20 degrees (190-210 over the course of a 3 minute wait) and I know my system has been bled properly.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  10. #10 Re: Car cooling fans not working + overheating issues PLZ help.
    Sep 2012
    Bangor, ME
    Quote Originally Posted by 04GPWhite View Post
    With AC on, the fans should be running full time, not cycling.
    Question: At idle, if you turn your AC on (as long as its not already O/H) does your gauge start to drop or at least stop rising?
    GOD BLESS...
  11. #11 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    Quote Originally Posted by Chadgervais View Post
    Gauge does stop rising when a/c is on at idle. I will try to bleed the system again tomorrow, and replace the temp sensor again. I dont see why though when I move the wires that run into back of fuse box would cause the fans to turn off even when the a/c is on.
    This all started when them dam 90 degree elbows busted.
  12. #12 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    This morning I tried to bleed the air out of the cooling system. When car first started to warm up, it slowly was pushing air bubbles out, and the I revd the engine up to 2000 rpms for a lil bit and when I let of the gas a lot of coolant just rushed out. I then let the car idle more, and I added some more coolant. Then i revd up to 2000 rpms again. By this time car was starting to overheat, and soon after coolant was just being pushed out. Fans still did not come on.
  13. #13 Re: Car cooling fans not working + overheating issues PLZ help.
    Sep 2012
    Bangor, ME
    Cant help but wonder if maybe the electricals took a bath in coolant when the elbow went? Water in the wiring could easily cause the fans to be sketchy.
    GOD BLESS...
  14. #14 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    I disconnected the ECT and my fans kicked on full blast. I drove the car to Oriellys to get another ECT. When I got back home i plugged the ect back in and the car was overheating. Low coolant?
  15. #15 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    when I plugged the ECT in the fans immediately turned off
  16. #16 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    Ok well I replaced the ECT. The one i bought today at Oriellys had longer prongs inside and the other one I bought before at pepboys had short ones. So im guessing it wasnt making enough contact with the sensor and/or Pepboys gave me the wrong ECT. Fans work with the new ECT. Now I have no heat in the heater, and car was overheating. So Im guessing i have more air in the system now.
  17. #17 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    nevermind. Tstat wont open now, and fans still not kicking on.
  18. #18 Re: Car cooling fans not working + overheating issues PLZ help.
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Sounds like you have air in the system since you replaced the elbows. Do this.
    1. Remove thermostat housing from top of engine.
    2. Fill with coolant.
    3. Squeeze lower radiator hose to force air from the system.
    4. Top of again
    5. Reinstall Housing
    6. Open up radiator cap.
    7. Fill with coolant
    8. Squeeze upper radiator hose to get air out.
    9. Fill with coolant
    10.Replace Cap
    11. Fill overflow
    12. Start car with heat on for about 15 min and let it come up to temp
    13. Shut it off, let it cool and then top of reservoir.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  19. #19 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    i will try this thanks man
  20. #20 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2012
    Fresno
    I did what you said bro. And for now it didnt overheat when at idle but did get almost to the 3/4 mark. Fans still did not kick on though.
  1. Cooling Fans Not Working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 09-02-2011, 10:24 AM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. cooling fans not running and overheating.
    By gtp40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 07:46 PM
  4. 1994 gtp cooling fans not working
    By almighty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-01-2010, 09:39 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
