My fan's don't kick on until I get past 3/4 as well. I would check the relays again. Did you also check all the fuses as well? Maybe you have a bad fuse somewhere.
Worst case scenario, just drive with the AC on.
Hey. Hope someone is still reading these. Last thread was a while ago. I’m having close to the same trouble as 04GPWHITE but, my issue is that the fans won’t turn on AND the gauge stays low. I have a scanner and it will go up to 215 degrees before I chicken out and command the fans on(which works fine) and cool it down manually. Fans work when commanded. Relays all good. Ect checks out with ohm meter. If the instrument cluster goes bad will that cause issues or would it be the pcm?
