Thread: Is there no answer to constant leaking plastic elbows?
Results 1 to 13 of 13
  1. #1 Is there no answer to constant leaking plastic elbows?
    Apr 2009
    vegas
    These dam plastic cooling elbows are a pain in the ass! I have replaced them three time in the last year and a half. The first couple lasted about 6 months, and thi last set I canged only about two months ago and now the bottom one is leaking again.
    Has any one fould a solution to seal them any better or make them last any longer?...
  2. #2 Re: Is there no answer to constant leaking plastic elbows?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    RTV I have hear can seal up around them pretty good from what I have heard. If you are having issues with the elbow itself cracking look into aluminum elbows.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Re: Is there no answer to constant leaking plastic elbows?
    May 2008
    Schuyler, NE
    Put a bead of RTV on before/ontop of the orings. I've never had a leak with this method.
  4. #4 Re: Is there no answer to constant leaking plastic elbows?
    Dec 2008
    Lawndale, CA
    Go back to using the GM one's or replace the o-rings on the dorman one's with the delco o-rings. I ended up going back to delco elbows and used a little RTV this last time.
  5. #5 Re: Is there no answer to constant leaking plastic elbows?
    Bellevue, Neb. Close to Omaha
    I've changed them five times over the past 2-3 years. I've tried installing them dry, with a little oil on the o-rings, light silicone and now with more silicone. I keep having the same elbow leak: where the top elbow enters the intake manifold.
    So far I have been good, but who knows?
    I'd like to try the aluminum elbows if they actually seal better.
    This is just an ill design. I also notice some slight seepage around one of my lower intake manifold bolts, so I think I will be taking this all apart again all too soon to deal with another yet another cooling leak.
  6. #6 Re: Is there no answer to constant leaking plastic elbows?
    SE Level Member GT in Kennesaw's Avatar
    Kennesaw, GA
    There are these - Aluminum Coolant Elbows #ZZ-ALCE, aluminum coolant elbows from ZZ Performance. These should be the last elbows you ever need.
    Quote Originally Posted by GT in Kennesaw View Post
    Don't get ripped by ZZP prices and just buy from rockauto...
    04 Comp G.
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    They are $12 shipped, took 3 day's to get here. My only options were Napa, O'Really, and Auto Zone. None of them stocked them nor could cross and find the aluminum elbows for me. So sometime's this is the best option.
    Sent using Tapatalk 2 from my GS3.
    Nothing wrong with that. I just recall when Zzp starting selling them they were more expensive then what Rockauto was selling then for. I guess they adjusted the price since then.
    04 Comp G.
  10. #10 Re: Is there no answer to constant leaking plastic elbows?
    So are the aluminum elbows better in that they seal better, or is it just because they don't crack?
  11. #11 Re: Is there no answer to constant leaking plastic elbows?
    Dec 2008
    Lawndale, CA
    They still use the same o-rings.
  12. #12 Re: Is there no answer to constant leaking plastic elbows?
    Kennesaw, GA
    It's the heat and age that causes the plastic to crack, usually at the weak point, where the o-ring goes, or along the seam. Mine crumbled into many pieces that I had to dig out. The aluminum won't crack or snap off.
  13. #13 Re: Is there no answer to constant leaking plastic elbows?
    Jul 2012
    Chicago
    Put the aluminum ones in when they first came out, haven't had an issue.
    -Carl
  1. I Hate plastic coolant elbows!!!!
    By Ace in forum The Rant Forum
    Last Post: 11-07-2012, 06:35 AM
  2. damn elbows leaking again
    By gotgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2012, 11:58 AM
  3. Replaced coolant elbows..leaking again
    By MattTheBaker123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2012, 06:17 AM
  4. Damn constant repairs!!!
    By WhiteGT in forum The Rant Forum
    Last Post: 05-23-2009, 05:05 PM
