Thread: Help! 2004 Grand Prix GT misfire
Results 1 to 5 of 5
  1. #1 Help! 2004 Grand Prix GT misfire
    SE Level Member Scott Gerhart's Avatar
    Aug 2012
    Reading, PA
    I had a coolant leak and unfortunately had an emergency to go to and limped the car there while overheating. Worst possible timing. Coolant leak fixed and now the engine has a very slight misfire only while idling. My mech buddy said it might be a bent connecting rod. I'm trying to explore all possible options before I would just replace the motor. He checked the valves and they looked ok. It's cylinder 3. Any ideas?
  2. #2 Re: Help! 2004 Grand Prix GT misfire
    Do a leak down test and compression test on cly 3 and all the rest if your gonna do it. Make sure you didnt warp something or pop a gasket first
    SMGPFC Member #10
    Aug 2012
    Reading, PA
    Did a compression test and cyl 3 was only slightly lower than the others. Replaced plugs and wires. Any O2 sensors or the MAF sensor that could cause it? Trying to think of stuff that could be simple. Clogged injector? It got really hot. Maybe a hole in the intake manifold? That's plastic
  4. #4 Re: Help! 2004 Grand Prix GT misfire
    St. Louis
    Bad coil? Could try swapping coils and see if the miss follows or stays on cyl 3?
  5. #5 Re: Help! 2004 Grand Prix GT misfire
    Jan 2015
    Louisiana
    This may sound really stupid but remove your air filter housing and inspect the insides fully for excess trash, leaves, plastic shopping bags, etc. I just experienced a rough idle and a misfire on cyl #2 (P0302 code) --- I found 2 plastic shopping bags sucked up into the front of the air filter housing and they had about 40-50% of the airway clogged up. Removed the plastic bags and put it back together. It seems as though the problem is solved. It won't hurt anything to check it out and clean it while you have it out. This very well could be your problem.
  1. grand prix misfire
    By patrick 721 in forum Introductions/Noob Questions
    Last Post: 11-28-2012, 02:34 PM
  2. Replies: 7
    Last Post: 06-25-2012, 03:34 PM
  3. p301 misfire '02 Grand Prix SE
    By sicayan in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-28-2010, 08:00 PM
  4. 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    By srlash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 10:00 PM
  5. 96 grand prix misfire
    By krcorbett in forum General Tech Discussion
    Last Post: 10-13-2009, 03:56 PM
