Thread: 97 grand prix won't start
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: 97 grand prix won't start
    I'd get to checking what Bill said, but if the LIM/UIM need attention I wouldn't let it get behind ya, those are pretty important.
  2. #22 Re: 97 grand prix won't start
    Thing here is..something has to be missing or bad.
    You can't have compression fuel and spark with the correct timing w/o it starting. So some sensor is likely holding you back.
  3. #23 Re: 97 grand prix won't start
    May 2008
    Fond du lac, WI
    I agree with both of you, just don't have acess to the car right now til probably tuesday and yes the plugs were pretty drenched in fuel when I changed them.
  4. #24 Re: 97 grand prix won't start
    Ok, then either you turned the key on and off a ton w/o it starting (primes every time you go on from off) or something is causing you to get too much fuel on prime.
  5. #25 Re: 97 grand prix won't start
    May 2008
    Fond du lac, WI
    It was cranked over alot by the owner and her brother and neither knew about it priming every time you turn the key on.
  1. 94 Grand Prix will not start
    By AMXTRA in forum General Tech Discussion
    Last Post: 10-07-2012, 04:20 PM
  2. 99 Grand Prix GT No Start
    By Ryan852 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2011, 07:33 AM
  3. 97 Grand Prix Gt will not start
    By RicksGT in forum General Tech Discussion
    Last Post: 12-17-2010, 06:42 PM
  4. 99 Grand Prix GTP no start
    By atvrider85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2010, 11:26 AM
  5. Grand Prix won't start - 99 GT
    By socaljay66 in forum General Tech Discussion
    Last Post: 11-10-2009, 07:14 AM
