Thread: Leaking coolant, even after replacing water pump
Results 1 to 12 of 12
  1. #1 Leaking coolant, even after replacing water pump
    Jun 2012
    Westland,Mi
    I was driving down the road, lost heat inside the car, I pulled into a gas station and it was leaking coolant all over. The engine was smoking badly.
    Replaced the water pump assuming that was the issue, after that it is still leaking and still doesn't have heat inside the car. The temperature gauge says it's at operating temp a lot faster than normal.
    Here is a picture, the coolant is leaking around the black tube that is circled in red.
  2. #2 Re: Leaking coolant, even after replacing water pump
    Replace the elbow.
    Dorman number 47065 for new plastic ones
    Dorman number 47065hp for aluminum ones
    http://www.grandprixforums.net/how-c...ows-49779.html
  3. #3 Re: Leaking coolant, even after replacing water pump
    Yep ^^^
  4. #4 Re: Leaking coolant, even after replacing water pump
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    make sure the hose that connects from your radiator cap to the reservoir isnt cut. mine was sliced into from the pulley and alot of coolant flew right under that elbow .
  5. #5 Re: Leaking coolant, even after replacing water pump
    Jun 2012
    Westland,Mi
    1 Bloody knuckle and a few hours later, the elbows are replaced,the hose from the cap to the resivoir is fine, I have a new water pump in,and still no heat. I started it in the driveway and let it run for a few minutes with the hood open,and it seemed fine but no heat and the temp guage was staying pegged at cold so I took it around the block. On that 2 minute drive it jumped up to 3/4 up the coolant temp guage and was smoking again,still no heat. Before starting it i checked and there is half a tank of coolant in the resivoir and I filled the radiator to the top. After the drive I didn't check it yet,ill go back out in the morning,its 1am right now. Anyone have any suggestions for what to check next? I dont see it leaking anywhere but it sounded like it was boiling and it was smoking/steaming.
  6. #6 Re: Leaking coolant, even after replacing water pump
    take both hoses off th ealt bracket, and flush one with a garden hose, to fill the heater core.
    then bleed the air out via the t stat housing, and top off the coolant.
  7. #7 Re: Leaking coolant, even after replacing water pump
    Sounds like you need to bleed the system
  8. #8 Re: Leaking coolant, even after replacing water pump
    Pull the thermostat and fill through threre. The system sounds air bound. This is the easiest and quickest fix. Apply a light amount of RTV to the thermostat housing when you put it back together.
  9. #9 Re: Leaking coolant, even after replacing water pump
    Jun 2012
    Westland,Mi
    ok well I filled the system through where the thermostat goes, and in the hose to the radiator, and in the hoses to the heater core, and the top of the radiator, and in the reservoir, I had heat for a few hours, then suddenly I'm back to no heat, and its leaking again, I see it dripping from the subframe underneath but can't see anything from above. It's not leaking from the elbows or water pump, so I'm kinda lost.
  10. #10 Re: Leaking coolant, even after replacing water pump
    Sep 2015
    hilton, ny
    I have a similar problem, drove about 2 mile first thing in morning temp gauge shot all the way up to red. changed them and water pump. now leaks when running took to mechanic was told leaking from plastic elbow I assume head meant on the intake. want to charge me 400 to fix can I do myself how do I get to them..
  11. #11 Re: Leaking coolant, even after replacing water pump
    Sep 2015
    hilton, ny
    I have a similar problem, drove about 2 mile first thing in morning temp gauge shot all the way up to red. changed them and water pump. now leaks when running took to mechanic was told leaking from plastic elbow I assume he meant on the intake. want to charge me 400 to fix can I do myself how do I get to them..
  12. #12 Re: Leaking coolant, even after replacing water pump
    yes you can.
  1. Any ideas? Broken coolant elbow won't come out of water pump..
    By CRU1Z3R in forum General Tech Discussion
    Last Post: 04-27-2012, 05:04 AM
  2. water pump or coolant elbows?
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 12-10-2011, 03:20 AM
  3. 2000 GTP water leaking into interior
    By tjberens in forum Introductions/Noob Questions
    Last Post: 03-21-2011, 11:17 PM
  4. Leaking Water Through Sunroof !?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-10-2010, 12:06 AM
  5. replacing my water pump
    By joeyt637 in forum Introductions/Noob Questions
    Last Post: 08-16-2009, 10:11 PM
