Thread: HV3 High Velocity Intake Insert
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: HV3 High Velocity Intake Insert
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    Quote Originally Posted by smoke14 View Post
    Yes it will (and sound awesome) however, I'd suggest doing just those 3 simple mods at the same time along with any maintanince that your car needs.
    Is that better then buying a CAI? Sorry for the noob questions...the the three mods I should do is the PCM,hoome made intake and HV3 inserts right?
  2. #22 Re: HV3 High Velocity Intake Insert
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Tune should be last, first you put the mods on that you want then you get a tune telling the tuner what mods you have so he can adjust the tune accordingly, if its a mail tune you order.
    if you have a tuner in your area then the tune will be that much better cause they can tune to your exact car.
    I made my intake, got the downpipe, got the hv3, then got a custom incar tune from :: Overkill Motorsports ::
    as for beating a stock gtp.. I beat a stock bonneville SSEI which is the exact same car as a gtp, but the bonneville is 300 pounds heavier and longer geared so im guessing the gtp would be just as fast if not faster as my bolton car. driver race really.
    but at the same time i pulled a 15.6 in the qtr mile.. stock gtp's if driven right are 14.5-14.9 in the qtr
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #23 Re: HV3 High Velocity Intake Insert
    I've never done a case learn with swapping pcms. You should be able to pull the old pcm out and put the new one in and fire it up and go. No need to spend $200 bucks. Use that money and buy headers.
  4. #24 Re: HV3 High Velocity Intake Insert
    Nov 2012
    United States
    my friend told me I be fine with just a CAI and new headers, no PCM, is that true?
  5. #25 Re: HV3 High Velocity Intake Insert
    Apr 2012
    Goderich, Ontario
    No, headers will give you a ses light (P0420) without a tuned PCM.
  6. #26 Re: HV3 High Velocity Intake Insert
    Dec 2008
    Lawndale, CA
    If you want a little more power then go with the following mods on a GT
    Intake of your choice
    HV3
    ER Rockers or cam
    Plog/Down pipe or headers
    Exhaust
    Tuned PCM
  7. #27 Re: HV3 High Velocity Intake Insert
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Glad someone brought it up! before you start odding ANYTHING on your car...read this...http://www.grandprixforums.net/safel...0-a-67580.html
    study it..know it..in the end, if you follow the write-up, you'll save yourself alot of time, headaches, and most importantly ....MONEY!!
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  8. #28 Re: HV3 High Velocity Intake Insert
    Jun 2015
    Superior, WI
    Any updated link to your reply, found this post researching on web and wanted to read from your link, said not found in forum...
  9. #29 Re: HV3 High Velocity Intake Insert
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  10. #30 Re: HV3 High Velocity Intake Insert
    SE Level Member Acdc88's Avatar
    Jul 2015
    St Peters
    FYI. Make sure to research torque specs for UIM gasket before installing.
  11. #31 Re: HV3 High Velocity Intake Insert
    Lol, torque specs.
    German torque specs are all you need: GUTENTITE.
  12. #32 Re: HV3 High Velocity Intake Insert
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'd recommend performing the routine/preventative maintenance as described in the "safely modding your 3800" thread before spending any money on modifications. If you can't perform the basics you're going to be at the hands of dealers and shops who are "modding" your family sedan. If you can work through the maintenance items, you'll likely be much more comfortable around your engine and likely able to easily perform your own modifications. You'll also have a variety of tools and a car that is in great mechanical condition.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  13. #33 Re: HV3 High Velocity Intake Insert
    Quote Originally Posted by stocker View Post
    See, this guy knows.
  1. high velocity intake insert
    By RyanL in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:16 PM
  2. Question on HV3 High Velocity Intake Insert
    By btr09 in forum General Tech Discussion
    Last Post: 02-12-2010, 10:06 AM
  3. HV3 High Velocity intake insert
    By Kerker48 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 12:10 PM
  4. High velocity intake insert?
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2008, 10:04 AM
