Thread: Broke The Fuel Quick Disconnect..
Results 1 to 20 of 22
  1. #1 Broke The Fuel Quick Disconnect..
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    2000 Gp L26 how can i go about repairing the fuel line? got a junk yard up the street just waiting for me to pop up.. can some one point out where and how this disconnect line can be removed? hopefully i dont got to replace the whole damn fuel line
  2. #2 Re: Broke The Fuel Quick Disconnect..
    what broke? or is it just leaking? if its leaking, you can replace the O rings inside the line.
  3. #3 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    you know the 90 degree elbow? that snaps onto the fuel rail.. theres actually two lines that snap to the fuel rail.. i broke one of the elbows in half lol
  4. #4 Re: Broke The Fuel Quick Disconnect..
    ouch!
    theres a dorman kit to repair that i think.
  5. #5 Re: Broke The Fuel Quick Disconnect..
    Often at your local parts store
  6. #6 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    id rather jus replace is because i dont want that thought in the back of my head that if i stomp the gas that could burst and wala got another burnt up GP
  7. #7 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
  8. #8 Re: Broke The Fuel Quick Disconnect..
    That lines goes to the fuel tank
  9. #9 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    so is removable before entering the tank? or does tank gotta be dropped?
  10. #10 Re: Broke The Fuel Quick Disconnect..
    to swap that line..you have to drop the tank, sometimes the subframe etc etc..it's not easy. Swapping the end would be easier
  11. #11 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    how would i do that? just pull that piece out and shove another in?
  12. #12 Re: Broke The Fuel Quick Disconnect..
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by mofford12 View Post
    I replaced the other rail line and connector on my car a few months ago...no problems with it. If you have any questions with the repair, judst let me know
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  13. #13 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    Quote Originally Posted by bayus2972 View Post
    the whole line?
  14. #14 Re: Broke The Fuel Quick Disconnect..
    You could use rubber fuel injection hose to fix it. I did that on my buddies pa a while back and double clamped it on each side.
  15. #15 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    Dorman Products - 800-059 <<<< this is the one i bought and its wrong
    http://www.summitracing.com/parts/rn...9/media/images <<<< this is the one i need.. look at the clips theres a difference...
    one thing after another i sware
  16. #16 Re: Broke The Fuel Quick Disconnect..
    SE Level Member Robby Avery's Avatar
    Deep South Georgia
    Autozone sells them the feed line elbow for 20-25 bucks I had to replace my gf's the oring was gone pouring gas into valley got lucky and never had a problem or fire. They also sell the return line elbow like your needing for about the same price. Make sure you remove the OEM clip as the dorman piece has its own quick-disconnect built in. You just splice into the stock line with a double ended barbed fitting and your done. It takes some elbow grease to get the barb in the line so I highly doubt you'll blow it loose at WOT.
    Girlfriend's ride: 03 Summit White Grand Prix GT 180* T-stat, Autolites, Bosch wires, Custom CAI
    My Rides: 2006 LBZ CCSB LT3 Duramax Diesel Puller/DD
    2002 LB7 Duramax Diesel CCSB LT3 to many mods to list! Work Truck/DD
  17. #17 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    all is well she is back an running good as new!
  18. #18 Re: Broke The Fuel Quick Disconnect..
    Buffalo, NY
    I'm guessing you used the repair kit? I have the exact same problem, and I also had the wrong kit from AA; did the 800-059 from Summit fix the problem?
  19. #19 Re: Broke The Fuel Quick Disconnect..
    Nov 2012
    Cincinnati
    I didn't get the one from summit.. we have a local auto parts called Smyth I went to but yea it fixed.. it was relatively easy.. did you break the supply line or return line?
  20. #20 Re: Broke The Fuel Quick Disconnect..
    Buffalo, NY
    It was the return line. I was thinking it was 5/16 on the return and 3/8 on the feed.
  1. quick disconnect cooler line on bottom of the rad
    By tonglebeak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2012, 07:03 PM
  2. Quick disconnect fitting question
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2012, 01:31 PM
  3. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
