Thread: Engine Codes P0171 and P0102 need help
Results 1 to 9 of 9
  1. #1 Engine Codes P0171 and P0102 need help
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    So about last week Wednesday my car (2000 GT) started to feel like it was misfiring or something. Car has 153,000miles so its probably time for something to be replaced. The engine light did not come on right away and I was not sure what was going on. Eventually the light came on (first time in the 2+ years of owning the car) so I took in to an auto parts store and it gave codes P0171 for System Too Lean (Bank 1) and P0102 Mass Air Flow Low Circut Input. I pulled out the MAF and cleaned it again and put it back in. Still have the problem. Someone told me its possible that I have a vac leak so I sprayed ether stuff all around and engine did not jump so I figured it was not that. O2 sensor is the only thing I can really think of that may be causing the problem because the MAF looks perfectly fine. I thought that there was a test that you could do by unplugging the O2 and seeing how it ran or something but I am not sure. Any help is appriciated. I've been pretty busy with school and stuff so I might not be on here much to give feedback but we will see.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Engine Codes P0171 and P0102 need help
    It's not the O2 sensor. The issues you are having are caused by P0102 and since you know that's an issue with the maf, check the wiring to it and replace the maf.
  3. #3 Re: Engine Codes P0171 and P0102 need help
    Alright. Is there any way to check the voltage of the maf wiring to see if the wiring is good or bad? The maf sensor itself does not appear broke and looks mint yet. Id hate to spend like $150+ on that part on find out thats not the problem.
  4. #4 Re: Engine Codes P0171 and P0102 need help
    Dec 2012
    Redlands, CA
    Hi, I have a similar problem as I first had a P0102 code. I actually replaced my MAF sensor with a used one from the junkyard. It came of a 3.8 Camaro and the part numbers matched. After installing it, it threw another code P0171 which to my understanding is also MAF related. Should I just buy a brand new one? I'm really trying to save myself a $150 investment. I recently replaced all the vacuum hoses and checked for leaks.
    Before replacing the MAF the car ran fine but would stall only in cold and high moisture conditions. I did the unplug test, with no difference. That told me that I needed to replace the MAF. Now the car is idling rough, but not stalling anymore. Thus, giving me P0171.
    *Note: 1999 Pontiac Grand Prix GTP (VIN "1")
  5. #5 Re: Engine Codes P0171 and P0102 need help
    Pennsylvania
    Dirty MAF? Spray it down with MAF cleaner.
  6. #6 Re: Engine Codes P0171 and P0102 need help
    also check the wires to the plug for the maf, look for bare wire or cracks in the wire insulation, any bare wire showing and thats your issue.
  7. #7 Re: Engine Codes P0171 and P0102 need help
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Here is how to check with a meter :
    Part 1 -MAF Sensor Test: GM 3.3L, 3.8L
    1997 Red GTP 182000 miles stock
  8. #8 Re: Engine Codes P0171 and P0102 need help
    Dec 2012
    Redlands, CA
    I cleaned the MAF before putting it in. I actually went ahead and just bought a new one, at least then I can eliminate the part of the problem. All wiring looks good to the MAF. There has been tampered with the wiring for the MAP and TPS sensors though, but nothing bare showing. I was going to redo the wire buds and see if that would eliminate the problem.
  9. #9 Re: Engine Codes P0171 and P0102 need help
    Just a late update on what the problem was with my car. It did turn out to be the MAF sensor. Solved all my problems.
  1. Check Engine Codes P0120, P0113 and P0171
    By 71gs3504sp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2012, 12:00 PM
  2. P0171, P0440, P0443 codes
    By stevenj in forum Engine
    Last Post: 10-29-2012, 09:29 AM
  3. Code P0171 and P0102
    By Kelime in forum General Tech Discussion
    Last Post: 11-17-2011, 05:26 PM
  4. Need help finding out what i need to fix! P0303 and P0171 codes
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 08:45 PM
  5. PLEASE HELP! Codes P0102 & P0452
    By TAWinner23 in forum General Tech Discussion
    Last Post: 09-17-2008, 02:11 PM
