Thread: Hard to start Fuel pump?
Results 1 to 5 of 5
  1. #1 Hard to start Fuel pump?
    Dec 2012
    ks
    I have a 04 it cranks and cranks I cleaned the tb and put in a new fuel filter I have found that if I turn the key on and off like 4 times befor i try to start it then it fires right up where would the fuel pressure be going?
  2. #2 Re: Hard to start Fuel pump?
    check the fuel rails fuel pressure. could be the pump going bad.
    the check engine light on by any chance?
  3. #3 Re: Hard to start Fuel pump?
    Dec 2012
    ks
    No the light is off and I have no codes
  4. #4 Re: Hard to start Fuel pump?
    rent a fuel pressure tester, it screws onto the fuel rail, front side of the engine.
  5. #5 Re: Hard to start Fuel pump?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Same thing happens to me and I lose all my pressure when I turn the key off. Replaced the fuel pressure regulator and injectors so I'm guessing fuel pump
  1. No Start-Fuel pump?
    By Freddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 01:24 PM
  2. grand prix wont start, fuel pump is good.
    By 1986c10 in forum General Tech Discussion
    Last Post: 12-19-2011, 08:51 PM
  3. No start: Fuel pump or resistor perhaps?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:43 PM
  4. Car will not start, possible fuel pump fail
    By osbornb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2010, 12:01 PM
  5. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
