Thread: Engine Vibration Question
Results 1 to 5 of 5
  1. #1 Engine Vibration Question
    Apr 2012
    NoWhere
    I have a 2001 pontiac grand prix gt with a 3.8L N/A motor w/ 120,xxx miles. A FWI, glass pack res, 180* T-stat, flowmaster mufflers. I recently changed the PCV valve, spark plugs and wires(factor AC Delcos), changed the oil, ran seafoam and Chevron fuel system cleaner. Changed the fuel filter, did a radiator flush and replaced the radiator(unrelated repair), replaced the throttle body inlet screen since I broke the other one attempted to clean the throttle body. All of the wires are secure and the idle(RPMs) aren't surging at all but the car has a very strong vibration, I inspected the top 2 mounts and they seem to be in working order and driving I feel no loss in power and there is no hesitation so I have kind of ruled out a fuel or spark problem. I believe I have tried mostly everything except for replacing the two easily visible mounts. Has anyone else had this problem or can someone recommend the next course of action I should take(I am trying to avoid a trip to the mechanic, I'm not trying to pay for him to guess the same way I did). Any help will be greatly appreciated.
    Thanks
  2. #2 Re: Engine Vibration Question
    Aug 2011
    'Merica
    motor mounts?
  3. #3 Re: Engine Vibration Question
    Apr 2012
    NoWhere
    The top two mounts were pretty loose, I tightened them and there is a noticeable difference in the engine vibration. Does anyone know where the mount at the bottom is and how easy/difficult it is to change?
    Thanks
  4. #4 Re: Engine Vibration Question
    you have 2 lower mounts, one is the trans mount the other is called a motor mount, the to up top are called strut, and mounts. where they bolt to.
    heres a vid for the tranny mount, the engine mount is done the same way. its a 3 part vid.
  5. #5 Re: Engine Vibration Question
    Ontario
    Mounts and axles. Many have this issue, as previously stated, check the condition of the lower mounts and axles
  1. Severe engine vibration. Please help.
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-11-2012, 10:54 PM
  2. Violent engine vibration
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-03-2012, 06:43 PM
  3. engine rough shaking/ chugging vibration
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2011, 02:58 PM
  4. 04 grand prix - finding vibration question
    By echasel in forum General Tech Discussion
    Last Post: 02-08-2011, 01:38 PM
  5. engine question
    By fabz77gp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 09:25 AM
