Thread: Ported exaust manifolds
Results 1 to 20 of 20
  1. #1 Ported exaust manifolds
    Jersey
    Ported Exhaust Manifolds: 3800 Performance
    any thoughts on these? or are the ZZP ones better?
    16' wrx sti- stock
  2. #2 Re: Ported exaust manifolds
    Jul 2008
    Germantown, Maryland
    do it yourself! haha, quit being lazy!
  3. #3 Re: Ported exaust manifolds
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I would spend the extra $130 and get pacesetters. Or minus $100 and get a plog, since the rear manifold isn't extremely restrictive [or so iv heard].
    2006 Grand Prix GXP
  4. #4 Re: Ported exaust manifolds
    Jul 2008
    btw, I hope you know I was joking with you above^^^
  5. #5 Re: Ported exaust manifolds
    Donating Users
    W-S, NC
    If you have the money, get headers. If not id go with the plog. It gives the engine bay a nice touch(if you get stainless), and saves you from buying dremel tool bits to port you stock manifold, and if you mess up the porting then you could mess the flow up.
  6. #6 Re: Ported exaust manifolds
    Oct 2008
    Michigan
    We do ported mani's to. $180 for ours, but I'm out of stock on them right now. If you want I can get a set here and have them done next week.
  7. #7 Re: Ported exaust manifolds
    Barksdale AFB, LA
    For N/A engines a Plog is plenty. No need for headers. Don't get ported manifolds since the front can't be ported past the primaries (where it needs it) and the rear isn't restrictive.
    2009 Subaru Impreza WRX STI
  8. #8 Re: Ported exaust manifolds
    Jul 2008
    East Freedom, PA
    hey guys just wondering what a Plog is.
  9. #9 Re: Ported exaust manifolds
    Donating Users
    W-S, NC
    Quote Originally Posted by static2489 View Post
    A Plog is a less restrictive manifold which increases exhaust flow therefore increaseing power and reducing KR.
    http://www.zzperformance.com/products_img/208_1.jpg
    ZZ Performance
  10. #10 Re: Ported exaust manifolds
    Jersey
    Would i loose some power if i get the pacesetter headers with 1-5/8'' primaries? they are almost as much as a full set of plogs from zzp.
    16' wrx sti- stock
  11. #11 Re: Ported exaust manifolds
    Donating Users
    W-S, NC
    Quote Originally Posted by 99prixgt View Post
    No you should gain power, but the pacesetters have had problems with sealing up flush and leaking. Unless your turbo, you dont need the rear powerlog. The rear mani. isnt nearly as restrictive as the front.
  12. #12 Re: Ported exaust manifolds
    Jersey
    thanx man, ill prolly just get the plog and call it a day, i was reading and with the cartuning turbo kit they recommend stock manifolds witch is odd...
    16' wrx sti- stock
  13. #13 Re: Ported exaust manifolds
    Donating Users
    W-S, NC
    Stock mani's? that is odd A smoother path and larger primaries (i.e. plog) would have a better flow. Just seems really odd.
  14. #14 Re: Ported exaust manifolds
    Hoffman/Schaumburg, IL
    ^^^Smaller primarys increase exhaust speed/pressure, spooling turbo faster
  15. #15 Re: Ported exaust manifolds
    Barksdale AFB, LA
    I think they mean that you have to use stock type manifolds with their kit. Otherwise it won't bolt up right. People have seen large gains going from stock manis to ZZPs front and rear Plogs on turbo setups.
    And, you can't use the rear Plog without a turbo setup. Can't use headers with turbo setup, so your choices become pretty easy.
  16. #16 Re: Ported exaust manifolds
    Donating Users
    W-S, NC
    Quote Originally Posted by 02BlueGT View Post
    Yeah the velocity would be greater. this is what i get for posting late at night lol. Good catch 02BlueGT.
  17. #17 Re: Ported exaust manifolds
    Jersey
    ah yes now this makes sense
    16' wrx sti- stock
  18. #18 Re: Ported exaust manifolds
    Donating Users chrisb's Avatar
    Bucyrus, OH
    actually they use the stock manifolds because they handle heat a lot better cause of there size and weight, so there less likly to crack then aftermarket manifolds, but thats why you go with stainless it normally solves that promblem. the plog is 5 pounds lighter then the stock front exhaust manifold so theres less material to handle the heat.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  19. #19 Re: Ported exaust manifolds
    Barksdale AFB, LA
    Weight doesn't tell you much about the mass. Since the stock manifolds are iron you could switch to steel and them be the 5 pounds lighter without sacrificing any material.
  20. #20 Re: Ported exaust manifolds
    Bucyrus, OH
    good point, im not familiar of the weight of cast to steal but if you look at the plog it is much thinner then the stock ones.
