Thread: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
Results 1 to 19 of 19
  1. #1 Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Heres the deal,
    The place I always go to get gas has the regular 87 for a couple cents higher than the other stations and they do not run ethanol in it. I have heard something about ethanol gumming up small engines and such and have heard that it can be kind of hard on cars. Now being a college kid now Im looking to save money here and there. This gas station sells the 90 for usually at least 10 cents cheaper than their 87 and is a couple cents cheaper than any of the other stations 87. The only thing is that it contains 10% ethanol. I probably do not need to run 90 because I have not modded my car at all yet and I may never. Just curious to see if this is a big no no. I realize that I will not be saving much but over time this adds up so every little bit helps. Do I need to worry about the ethanol causing problems or the octane being to high?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Sure, why not.
  3. #3 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Ethanol is actually good for your engine, it helps to clean it out not gum it up. You might see a very small decrease in your gas mileage though.
  4. #4 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Only issue is, it'll collect water if you store it.
    So use stabilizer if you're going to store.
    More octane is good.
    As slick said, mileage WILL go down.
  5. #5 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Its only 10% ethanol so he might not even notice, the guys that switch to E85 only notice about a 2-3 mpg decrease.
  6. #6 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    If you go open loop and go lean burn sure.
    Otherwise, you'll see a 3-8% drop instantly.
  7. #7 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Quote Originally Posted by slick2500 View Post
    I can live with a couple mpgs lost. As long as its not more than like 5. lol
    Dont plan on ever storing it. Right now its my one and only so I dont think itll sit unused more than maybe one day. And if it collects water fairly easy compaired to the non ethanol gas should I be sure not to run it low in the winter due to higher risk of the water in the gas freezing? I know its generaly not good to run it under a quarter tank if you can help it anyway.
  8. #8 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    In the winter you should always have half a tank of fuel in case you get stuck somewhere.
  9. #9 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    When would it be best to switch to the 90? Should I run it lower than normal like to the almost out of gas state or would it be better to slowly switch over to it by filling the tank when its half full?
  10. #10 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    just use it.
    there's nothing special unless you want to tune for it.
  11. #11 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Alright. Wasnt sure if it was bad to mix it or not. lol. Thanks for the advice.
  12. #12 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Here in Maine ALL gasoline is 10% ethanol. Never had an issue with my engine and the vast majority of my 220k miles were driven on Maine gasoline.
    I do wish i could get ethanol free gas... curious how it would run.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  13. #13 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Quote Originally Posted by Chadgervais View Post
    I got slightly better gas mileage since I started using it. On the highway I was lucky to get 28mpg and then i was getting 30-31 about 4 weeks ago when I checked. Part of it was cleaning the throttle body and new plugs and wires I'm sure. And most places around here have ethenol in all grades except maybe the 91 at some places. This station is a little different than the norm. haha
  14. #14 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Its pretty simple.
    More energy by volume, less volume required to achieve same amount of work.
  15. #15 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    GTP Level Member
    springfield IL
    There one station in my town I have found that has high octane gas with no ethanol.. I mostly run 91 octane 10% ethanol, every other tank I'll add some seafoam in...
  16. #16 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Adding the seafoam that often is a waste of money. Its really not helping anything, if the filter is new and you've run a cleaner in there before the fuel system should be pretty clean. Gas itself now can cleaning agents in it.
  17. #17 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    GTP Level Member
    springfield IL
    I change my fuel filter every summer since 2010..... So the sea foam is a waste huh...???
    a bottle of seafoam lasts me a few months, not mention sometimes I forget to add it in..
  18. #18 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    Ontario
    Race fuel for a race car. /wut
  19. #19 Re: Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    I was going off of your previous post saying that you do it every other tank. If you really did it that much, its a waste.
    Either way, with how often you change your filter and the gas quality these days, you shouldnt ever have to run any.
  1. 91 Octane
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2012, 11:15 PM
  2. possibly converting to ethanol
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2012, 05:18 PM
  3. 94 Octane w/ 10% ethanol?
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 04:26 PM
  4. Octane
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-18-2009, 10:20 AM
  5. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
