Thread: cooling fans
Results 1 to 18 of 18
  1. #1 cooling fans
    Sep 2012
    USA
    i just did a head and both intake gaskets, i no its not common that they go out. my cooling fans wont come on and they work before i started doing the gaskets. i replaced the temp sensor and still nothing, had a friend come over with his computer and try to remote start it and it worked so the relays are good. any ideas what else could be wrong? thanks
  2. #2 Re: cooling fans
    Apr 2009
    Fort Worth TX
    How hot is the engine getting?
  3. #3 Re: cooling fans
    Sep 2012
    USA
    about 210 and i did put in a new thermostat to
  4. #4 Re: cooling fans
    Apr 2009
    Fort Worth TX
    Have to let it get much hotter than that.
    Do the fans come on with AC?
  5. #5 Re: cooling fans
    Sep 2012
    USA
    when i turn the a/c on they dont come on
  6. #6 Re: cooling fans
    Seems kinda odd that they dont come on with the AC.
    But here is a picture of the fan settings.
  7. #7 Re: cooling fans
    St. Louis
    Check all your fuses (underhood and inside)?
  8. #8 Re: cooling fans
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by polarisdescent View Post
    My next question is:
    Does your AC work? If the system is interlocked by the pressure switch the fans will not come on.
    Fordman77
    His buddy was able to command the fans remotely so the fuses/relays should be good.
  9. #9 Re: cooling fans
    Keep in mind the screen shot from FFDP is a 2007. I have seen earlier models with slightly higher low speed fan settings.
    And...definately odd on the AC. Any codes popping up? Maybe the AC request is being overridded like Rico mentioned
  10. #10 Re: cooling fans
    2002 bill.
  11. #11 Re: cooling fans
    Small screen...sorry.
  12. #12 Re: cooling fans
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    It says that the CC override is disabled... Don't you want that Enabled?
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  13. #13 Re: cooling fans
    Quote Originally Posted by Sushamouf View Post
    No idea, that is a stock 2002 file from HPT.
    It says its a climate control override, I guess it for controlling the fans through the digital hvac system, I think, but I'm only guessing.
  14. #14 Re: cooling fans
    Jul 2010
    Coquitlam,BC,Canada
    There is your problem......the fans should be on with the A/C.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: cooling fans
    May 2011
    United States
    I would try enabling that, then see if they at least work with the A/C on.
  16. #16 Re: cooling fans
    Its not my car though lol, I was just showing the fan settings of a stock 2002 car.
    Its always disabled it looks like. The OP has to figure out why his fans arent working.
  17. #17 Re: cooling fans
    May 2011
    United States
    Hahaha I got confused, my bad.
  18. #18 Re: cooling fans
    Sep 2012
    USA
    put in 3 temp sensors and the third one work. thanks for all the help
  1. Cooling fans not funtioning
    By smits03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-04-2012, 06:22 AM
  2. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  3. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  4. HELP! cooling fans not running
    By nauss in forum General Tech Discussion
    Last Post: 09-15-2011, 02:20 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
