Thread: P/S upper engine mount
Results 1 to 13 of 13
  1. #1 P/S upper engine mount
    Mar 2012
    NC
    Hopefully this is the right place to talk about this...
    I've heard a lot of concerns revolving around the P/S upper engine mount breaking and have seen it break first hand on engines with a bit of torque. The factory unit as we all know is crappy aluminum that tends to snap. To stop this, I asked my dad to fabricate one for me out of metal.
    Now, this isn't exactly easy to do and is rather time consuming to get right. So, my dad came up with another idea that he and I believe would work very well. It's not nearly as complex but certainly adds quite a bit of reinforcement to the piece without all the effort.
    Now the big problem with this is, I'll be installing the all metal one because I can't be removing the IC every time the original bracket breaks and was kind of curious if you guys think this would help keep the mount from breaking in general. Let me know what you think. Maybe a volunteer to try it out?
  2. #2 Re: P/S upper engine mount
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Are those brackets custom? I thought the other side was the problem one.
    GPONA #1 Cyber Bully
  3. #3 Re: P/S upper engine mount
    Mar 2012
    NC
    Quote Originally Posted by blackspike2710 View Post
    This is the bracket I've seen snap first hand. If intercooled when using the Bonneville tensioner assembly, you need to use the crappy aluminum bracket. If it breaks then you need to disassemble the SC and IC to fix it. The metal bracket remedies that. But the two braces are what my question refers to. Could they help stop the breaking of the aluminum bracket?
  4. #4 Re: P/S upper engine mount
    Jan 2012
    Philadelphia
    thats pretty cool! i think it will work out well
  5. #5 Re: P/S upper engine mount
    Volunteering, if you are willing to have someone w/o torque test. I think it would.help, as long as the metal isn't able to pull/stretch, while the aluminum doesn't stretch as much.
  6. #6 Re: P/S upper engine mount
    Quincy, Mass
    My only concern would be if the bracket torques can the metal arms end up breaking the bracket. Remember the last time mine broke it was on the big flat tab.
    No more GP 04 Impala SS Indy:
  7. #7 Re: P/S upper engine mount
    FWIW when I have time (I know..it's a joke, but I like to dream), I plan on doing something similar to the top bracket. That is steel right?
  8. #8 Re: P/S upper engine mount
    Mar 2012
    NC
    The reinforcement brackets are made out of some sort of 5/16" hardened steel rod; they are a pain in the ass to bend. I think this would be a great solution to the problem. Whoever tests it needs to beat on the car a little bit...can you do that, Bill? LOL
  9. #9 Re: P/S upper engine mount
    I broke one with a stock L36.
    So bill should be able to break one easily.
  10. #10 Re: P/S upper engine mount
    Mar 2012
    NC
    On his stock L26 in his old man car? I don't know...lol
    Quincy, Mass
    We can put them on my car, I like looks of them a little better than my steel bracket in first pic. If I can't break it then you'll be fine.
  12. #12 Re: P/S upper engine mount
    I can abuse it. The new trans with all fresh packs hits pretty solid.
    Brian is an expert at breaking things though.
  13. #13 Re: P/S upper engine mount
    Mar 2012
    NC
    Quote Originally Posted by Swiggles View Post
    Actually, that's MY steel bracket in the first pic. LOL I don't care who tries them, but I need to know if they'll work for when I top swap my little bro's car.
  1. Cracked upper motor mount bracket
    By vailskier3 in forum 04+ Specifics
    Last Post: 04-16-2012, 02:11 PM
  2. Upper Engine Torque Strut Mount Bolt Question
    By janaya3 in forum General Grand Prix Discussion
    Last Post: 01-30-2012, 11:46 AM
  3. Rear upper strut mount
    By Ryan D. in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2011, 10:35 PM
  4. upper motor mount help please
    By Red_GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 01:28 PM
