Thread: GTP Question New To The 90 Degree Motor
Results 1 to 12 of 12
  1. #1 GTP Question New To The 90 Degree Motor
    Ohio
    ok i just bought a 2005 grand prix which is the base L26 model and im new to this forum
    So everyone knows im a GM certified tech and know alot about cars but not much bout the 90 degree motors so bare with me
    Ok sorry question is which is a better to do the top end swap which ive read alot about today on here or a motor swap... i ask because with the 04+ they use the electronic throttle body and i dont know what exactly will bolt to that... plus i dont know how much diffrentt the harness is from the L26 to the L32
    so yea help me out here
  2. #2 Re: GTP Question New To The 90 Degree Motor
    Oklahoma
    hmmmm, I thought to myself reading this, this is an easy question, then you brought up the electronic throttle. I know there are adapters to run the Gen V blowers on the L67's and other Gen III blower equipped vehicles. Since you already have the electronic throttle I would think it would just be a matter of getting a Gen V blower and LIM, crank pulley and so on.
    However, this is not exactly my area of expertise so I'll have to defer to someone that has actually done the swap.
  3. #3 Re: GTP Question New To The 90 Degree Motor
    Banned
    New Port Richey Florida
    Your better off doing the Whole swap. Because I've never heard of someone top swapping an 04+ L26 yet.
  4. #4 Re: GTP Question New To The 90 Degree Motor
    Barksdale AFB, LA
    Quote Originally Posted by 19SE92 View Post
    http://www.grandprixforums.net/f18/n...rged-6036.html
    Top swapping the L26 is the same as top swapping the L36, just you have to use Series III parts instead of Series II. 05+ L26 rods are plenty strong, so there's no real reason to want to go for the full L32 block unless you have to.
    You'll need...
    Heads
    LIM
    TB
    SC
    Crank pulley
    Idler pulleys
    Assorted vac lines, BBV wiring, MAP adapter (most likely), and probably reprogramming
    You can try to use the L32 computer, but it might be better to have someone with a tuner iron it out for you. Don't forget to have some intake and exhaust work done too. The higher compression of the L26/L36 blocks will make them more prone to knock so you need supporting mods to help fight this. The part I'm not sure about is how to convert from a return fuel system to a returnless fuel system.
    2009 Subaru Impreza WRX STI
  5. #5 Re: GTP Question New To The 90 Degree Motor
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Don't the L26's have practically the same return-less fuel system as the L32's? Or am I mistaken?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  6. #6 Re: GTP Question New To The 90 Degree Motor
    Ohio
    if i go with a l32 motor swap does that mean the fuel system is going to need redone ??????????
  7. #7 Re: GTP Question New To The 90 Degree Motor
    Barksdale AFB, LA
    I thought the L26 used a standard return fuel system. I could be wrong...
  8. #8 Re: GTP Question New To The 90 Degree Motor
    Jul 2008
    Dekalb, IL
    Just double checked and both the L26 and L32 have return-less fuel systems, so no need to change the fuel system other than the fuel rails.
  9. #9 Re: GTP Question New To The 90 Degree Motor
    Barksdale AFB, LA
    The data I have on the L32/L26 specifically says that the L32 is returnless but it never mentioned the L26 in that section. Oh well, must've been an omission.
  10. #10 Re: GTP Question New To The 90 Degree Motor
    Ohio
    ok but back to what i was wondering what ive read you have to run a bigger pully on a l26 because of the high compression which makes sense but later on down the road when i want more power what do i have to do then because i cant put a smaller pully on.... you know what i mean
  11. #11 Re: GTP Question New To The 90 Degree Motor
    Barksdale AFB, LA
    You can run the same size pulley, you just have to have the supporting mods like I was talking about earlier. Headers, catback, intake, cam or rockers, tstat, etc.
  12. #12 Re: GTP Question New To The 90 Degree Motor
    Ohio
    ok makes sense
  1. Another Blower Motor Question.
    By darylward in forum General Tech Discussion
    Last Post: 09-11-2009, 04:24 AM
  2. The motor out of the Z26
    By Zach3800 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2008, 01:12 AM
  3. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
