Thread: Coolant system help needed
Results 1 to 16 of 16
  1. #1 Coolant system help needed
    Donating Users onetyme77's Avatar
    texas
    I have a 98 gt pure stock. Recently had my water pump go out, had it replaced, then had it flushed, the mechanic was concerned saying it was still running on the hot side, drained and filled it then he said it leveled out to 210 or below. I've been closely monitoring my temps and it's staying around 195-210 (95° and higher temps in Texas) I still think that's a lil hot? Plus my over flow reservoir stays low (is that normal) is all of this normal? The car has 170+k miles one it.
    Tippy Tap'n with Tapatalk on my S3
  2. #2 Re: Coolant system help needed
    Pretty normal for a stock car. If you want it to run cooler you could get a 180* thermostat and tune for it.
  3. #3 Re: Coolant system help needed
    Stock thermostat is 195, so car runs at around 195-205, who woulda ever thought that would happen.
    The car is fine, wouldnt think twice about.
  4. #4 Re: Coolant system help needed
    Aug 2012
    SC
    Yep mine runs right around 195-205 as well, no adverse issues with it running at that temp, had to replace the water pump in mine as well when the weep hole finally went and started pissing coolant.......Should be fine One
    texas
    Quote Originally Posted by killswitch83 View Post
    What/Where is the weep hole
  6. #6 Re: Coolant system help needed
    Bottom side of the water pump.
    When the pump fails internally it can start to leak and the weep hole lets the coolant out.
    texas
    as I said I have had my water pump replaced, coolant system flushed, lower and upper intake gaskets replaced. Last night I was at the store and she decided to "pee" all over the ground, she never ran completely hot, once I started driving the temp would slowly drop down to just above 210, once I got home popped the Hood and heard hissing and spewing on the passenger side of the engine above the water pump. Here are a couple of photos, a friend of my said it's the 2 elbows attached to the tensioner pulley.
    Coolant system help needed Attached Images
    texas
    Sorry couldn't get the pics to post right
  9. #9 Re: Coolant system help needed
    Aug 2011
    Bucks County Pa
    It seems like you did not replace your elbow fittings!
    When you did the water pump you need to put in new elbow fittings there soooo cheap!
  10. #10 Re: Coolant system help needed
    Change the elbows they are $4 at autozone.
    texas
    OK I bought the elbow fittings and looked up a vid on YouTube http://www.youtube.com/watch?v=QldgV...e_gdata_player In the video his tensioner assembly needed 2 plastic fitting, mine doesn't, only the one going to the intake is plastic. And that sucker was not easy to get it, it took some exercise. Here are pic of mine front and back.
    Remove the belt, remove the alternator, remove the 4 bolts holding the tensioner assembly on, and pop it off, change the elbows, put it back together, the bolts will pull it all together so alternate when tightening.
    *sorry pics are sideways
  12. #12 Re: Coolant system help needed
    97&98 have that lower metal elbow just take the rubber oring and put it on the metal elbow.
    texas
    To late, it's all back together now
    Sent from my SCH-I535 using Tapatalk 2
  14. #14 Re: Coolant system help needed
    You didn't replace the o ring on the lower one? You'll be pulling it back apart soon then.
    texas
    Nope didn't know the one on the plastic one would fit, I would have had to cut the old one off and woulda been pissed if didn't have a replacement . I had no way to the part store, I had the car in peices, I'll deal with then. At least I will know exactly where the problem is.
  16. #16 Re: Coolant system help needed
    I reused a couple times. There's a chance it won't mess you up. If so.. just pull again and toss that ring on the lower.
    One note here for anyone searching in the future. 97/98 should be handled with care. If you put the wrong force (pulling) on that lower elbow you can break the timing cover where the elbow goes into it. Then you have bigger issue.
  1. Help Needed 99+ Coolant Bottle on 97
    By ill12will8 in forum General Tech Discussion
    Last Post: 03-18-2012, 12:25 PM
  2. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  3. Exhaust System Dilemma --- HELP needed
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2011, 03:34 AM
  4. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
