Thread: Chugging?
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 Chugging?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Recently, whenever I go to pick up speed, the car seems to be chugging and pulling back. Any ideas what this could be/way to fix this?
    Thanks
    -ljmonnin12
  2. #2 Re: Chugging?
    Pennsylvania
    Mileage?
    Modifications?
    Recent maintenance?
    Scan the PCM to see if any codes pop up, first. React accordingly. Parts stores do this for free.
    The following should help:
    Catalytic converter: clogs at about 150,000 miles
    Fuel filter: Change every 30,000 miles
    Intake filter: Change every 30,000 miles
    Pull and inspect sparkplugs and their gaps. Should be 0.60
    Stock sparkplugs are good for 100,000 miles. Replace with stock iridium plugs.
    Ensure that all vacuum lines are connected and no connections hav dry-rotted.
    Clean throttlebody butterfly plate with throttlebody cleaner, a rag, and toothbrush. Do not spray into intake.
    Clean mass airflow sensor with MAF sensor spray. Spray only, do not touch.
  3. #3 Re: Chugging?
    I could look at it for you tom if your not busy I work in minster and that's not to far for you. I can bring my scanner. I get off at 3 if your interested.
  4. #4 Re: Chugging?
    Nov 2010
    Sidney, OH
    Sorry I just got back on here. There's about 160,000 on the motor... 230,xxx on the body. The only mod is a CAI... It only does it after the engine has warmed up a little bit... Just put another trans in it in may.
    -ljmonnin12
  5. #5 Re: Chugging?
    so to maybe clear this up. at light throttle the tach bounces like 200 rpm and the car bucks?
    if so the tcc solenoid may be going out. have it scanned at a trans shop.
    this happened to my trans, it wasn't long before i lost 3 rd gear.
  6. #6 Re: Chugging?
    Does it have any codes?
  7. #7 Re: Chugging?
    Nov 2010
    Sidney, OH
    And it only does it when the car is warmed up and I've driven it for a while. How much did getting the tcc fixed cost? I know it will vary from shop to shop, but I'm just trying to figure out a ballpark figure.
    -ljmonnin12
  8. #8 Re: Chugging?
    i have no idea, my trans lost 3 rd gear, and i had a used one put in.
    mine also only did it after it was warmed up.
    did the check engine light come on yet?
  9. #9 Re: Chugging?
    Nov 2010
    Sidney, OH
    No, not yet.... I just had a used trans put in back in may.... Oye... and to top it off its a 97 vac trans.... I should of had them just rebuild it when it was in the shop the first time...
    -ljmonnin12
  10. #10 Re: Chugging?
    Nov 2010
    Sidney, OH
    More Information for ALLIANCE B21FLHB if I'm not mistaken, this is it right?
    -ljmonnin12
  11. #11 Re: Chugging?
    Apr 2011
    Elk Rapids, Michigan
    If it's like the problem I had, it would surge/hesitate between 2-3K RPM under light acceleration/engine load. I was told it was probably a TCC solenoid so I lived with it. I found a post on here or one of the other forums and it said to disconnect the battery(both cables) and the short them together for about 30 minutes. This resets the PCM and then after you hook up the battery again the PCM will relean your driving. It fixed my problem completely. It's an easy quick(and free) thing to try.
  12. #12 Re: Chugging?
    Nov 2010
    Sidney, OH
    Now that you said that, I do remember reading that somewhere but I forgot about it. Thanks! I'll try 'er out!
    -ljmonnin12
  13. #13 Re: Chugging?
    its usually more the sensor that controls lock up of the torque converter. it lets the trans lock and un lock, repeatedly. untill you give it more gas or let off it.
    its in the side cover of the trans and can be changed with out removing the trans.
    i'd go to a trans shop, if need be pay for a est to get it scanned. at least that way you know what your dealing with. from my own personal experience you dont want to let this go for to long.
  14. #14 Re: Chugging?
    re setting the pcm could fix it, but if its real bad it will start up again down the road possibly.
  15. #15 Re: Chugging?
    Nov 2010
    Sidney, OH
    Alright, I think I'll reset the PCM and see if it comes back, there might just be a possible rebuild in my gt's transmission's future. The shop I brought it to only charged $250 to put a trans in and it's $1000 for a rebuild....
    -ljmonnin12
  16. #16 Re: Chugging?
    Apr 2011
    When I reset mine, it came back about a month later. I reset it again and it hasn't returned. That was over a year ago. It's a free thing to do so it's worth a shot.
  17. #17 Re: Chugging?
    Nov 2010
    Sidney, OH
    Oook. Well, I tried reseting the PCM... No luck... Called my mechanic, he drove it, said the exhaust smelt like the car was running lean, checked the MAF... Dirt galore..... Maybe because about a week ago I found my open cone laying in the engine bay detached from the PVC pipe.... Ooops. Well, it runs a lot better now... Still a little bit of a hesitation/chug, but definitely a lot better than it was... Now I don't know how to completely get rid of it... My mechanic is busy and doesn't have time to really work on it.
    -ljmonnin12
  18. #18 Re: Chugging?
    Nov 2010
    Sidney, OH
    Alright... Well, I got a new MAF sensor.... and it still does it. And I literally just noticed something when I was driving it. When I put my car in park I'm getting a rough idle. It idles at about 750 rpms and the tach doesnt really bounce but just has a rough feel to it. Maybe TPS?
    -ljmonnin12
  19. #19 Re: Chugging?
    pull the tb off and clean all the sensors.
  20. #20 Re: Chugging?
    Aug 2012
    Doylestown,PA
    I have a 02 with 56K on it and it was doing the same thing. I got the cat replaced and it runs great again.
  1. chugging
    By Scottydoggs in forum General Tech Discussion
    Last Post: 08-20-2012, 12:41 PM
  2. 02 GT hesitation/chugging
    By justinmc84 in forum General Tech Discussion
    Last Post: 07-28-2011, 11:17 AM
  3. Chugging
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2011, 08:02 PM
  4. chugging
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2011, 06:01 AM
  5. Stuttering... Chugging?!?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 06:53 PM
