Thread: 99 Grand Prix GT Died and won't start
Results 1 to 4 of 4
  1. #1 99 Grand Prix GT Died and won't start
    Aug 2012
    Nebraska
    I have a 1999 Grand Prix GT that has 178,000 miles on it.... Daughter was driving it home the other night, and it got warm on her so she stopped and had coolant put in it, it cooled right down, she started to drive again and the service engine light came on and the car died, and now it will not restart. We installed a new fuel pump, new fuel filter, Cam sensor, crank sensor, temp sensor. We have good spark and fuel pressure... really seems like a timing thing, it will crank just fine, and when you let off of the key from trying to start it, it chugs like the timing is off.... Any ideas of what to check, I am at a loss on were to go from here??? Any input would be greatly appreciated.
    Thanks!!
  2. #2 Re: 99 Grand Prix GT Died and won't start
    Apr 2009
    Fort Worth TX
    UH Oh
    MAF
  3. #3 Re: 99 Grand Prix GT Died and won't start
    Where the plugs wet when they came out? The coolant loss points to either a external or internal leak. Since you didn't mention seeing any leak, then I'll assume internal. That would have me suggest you read this thread
    http://www.grandprixforums.net/97-03...ure-60667.html
    Then pull the TB off to confirm that there is coolant in the EGR area of the intake. If so.. replace intake (probably do LIM gaskets at the same time) and you are all set once the plugs and cylinders dry up.
    However I'd think you would get some starting and bad running from it.. Timing chains don't jump gears on these cars. Usually there are only a couple things that can go wrong. I'd be inclined to then try unplugging the maf like Rico suggests and maybe work the throttle a bit to get it running.
  4. #4 Re: 99 Grand Prix GT Died and won't start
    Aug 2012
    Nebraska
    Thanks for the input... We haven't noticed any external coolant leaks... I will try unhooking the MAF sensor and see if i can get it to run that way first.
    Thanks again!!
  1. Grand prix won't start
    By Latoya R Moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2012, 12:24 PM
  2. Motor died - multiple error codes - clueless where to start looking
    By Skrappi69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2011, 08:10 AM
  3. Car died and will not start
    By gofast84 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:25 PM
  4. 97 Grand prix won't start... Need help... BAD...
    By 98gtxking in forum General Tech Discussion
    Last Post: 10-08-2009, 10:50 PM
  5. 97 Grand prix won't start... Need help... BAD...
    Last Post: 09-24-2009, 02:54 PM
