Has anyone every moved it? its in the way when I go to put my CAI in from thrasher(40bucks). I was just wondering if I could change it to the later model ones too. Thanks
I'm also looking to do this. PM me if you find out what exactly you need to finish it.
Or you buy this one and get some hose from local parts store. Call it done.
http://www.grandprixforums.net/compl...uge-66067.html
I just drilled some holes in the strut tower where the overflow sits and set it up there bolted it fast and cut my overflow line to fit it. Pretty easy to do.
I did the Cai on mine , just bought one universal from advance , mounted it on left front above the pcm and ran a 3/8 hose over top of the fans , works great for the past 4 years or so
Go to JY with a 10mm socket and trim popper tool (aka screwdriver for some of you). Unbolt the tank and unclip the hose from the raaditor. Look down, there's a whitish piece sticking out. Pop the center out like any trim clip and it'll come right out. Put that white piece on your car and then drill two holes for screws to hold the top. Done.
My car didn't have a spot for that white piece so i'm running it without.
