Thread: Flashing Low Coolant Light, Coolant Full, No leaks
Results 1 to 7 of 7
  1. #1 Flashing Low Coolant Light, Coolant Full, No leaks
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    1997 Grand Prix SE 3.8 Series II
    178K miles
    Well my 'low coolant' dash light is flashing quickly on and then off in a repeating pattern. I see no leaks. Radiator is full and reservoir is above cold fill line. Coolant is nice and clean.
    Sorry to ask a question that's probably already been addressed... Is there a common cause for this? I'm thinking the sensor is bad or the harness is damaged. All gauges are fine and no SES light. No other dash lights on.
    I only ever had the SES light on once for a day with 'lean fuel bank II' due to loss of vacuum from throttle body/fuel pressure reg./transmission. Had my oil light blink on for 5 seconds a few months ago while backing out of a parking space on a hill. That's it the whole 20k miles I've owned this car. Guess I'd like to keep it that way. Thanks for advice.
    -Scott
  2. #2 Re: Flashing Low Coolant Light, Coolant Full, No leaks
    Topeka, KS
    Change your coolant sensor. It's probably got a bunch of gunk on it making it miss read. It's a very common problem.
  3. #3 Re: Flashing Low Coolant Light, Coolant Full, No leaks
    Donating Users
    Nov 2011
    Catskill Mountains
    I've got a similar issue with the cooling fans not coming on and the car is pissing a quart antifreeze after turning it off.
    Anything else to check?
    Thanks
    TPStatic
  4. #4 Re: Flashing Low Coolant Light, Coolant Full, No leaks
    Apr 2009
    Fort Worth TX
    Unplug coolant sensor and see if light goes out.
  5. #5 Re: Flashing Low Coolant Light, Coolant Full, No leaks
    KZOO, it's trying to tell you something. Honestly. it should either be on or off, not flashing. If I can..I'll look it up in the manual. year and model please.
    Static.. fix the leak. Likely it's the end tank of the radiator.
    Nov 2010
    Kalamazoo, MI
    Thanks Bill. It is a '97 SE with 3.8 N/A. It does get a little hot, goes a tiny bit past 210 in traffic idling but goes back down. Standard thermostat, properly bled it myself. Old radiator though.. Nothing obvious is wrong.
  7. #7 Re: Flashing Low Coolant Light, Coolant Full, No leaks
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Quote Originally Posted by KZOO3800 View Post
    Tiny bit past 210 in traffic is normal, weird, but normal. Dunno about the 97's but my 04's fans dont kick on until 217 ish. At idle i go up to 221 then back down to 200 before the fan shuts off. (190ish at highway speed, depending on ambient temperature). If its wicked cold and the heat is cranked and im going downhill, it will fall back into the upper 170's
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  1. Coolant light flashing, but it's full.
    By Paranoid in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-30-2012, 02:19 PM
  2. Coolant leaks
    By Kolton Lock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2012, 03:12 AM
  3. flashing low coolant light.
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2011, 03:55 PM
  4. my low coolant light is flashing, any suggestions?
    By amy in forum General Tech Discussion
    Last Post: 08-21-2009, 11:23 AM
  5. low coolant light flashing
    By BrokenRhythm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:09 PM
