Thread: coolant issues
Results 1 to 11 of 11
  1. #1 coolant issues
    Lakewood,Co
    So I had to replace my L36 a few months back. Had a shop swap it out. Runs great. After about a month the company I bought the engine from sent me 2 cooling system conditioner pills. Now my coolant looks dirty and despite my 180* tstat, she reaches 201* .The other day my dic said coolant level low./popped the Hood and overflow tank is at full hot. Get home and let her cool down, open the radiator and its a little low. Any ideas?
    180*, hv3, gutted air box w/ spectre air filter, zzp pcm, resonator deleted, ap605's gapped @ .055", zzp 10.3mm wires, MB Octane wheels, cross drilled/ slotted rotors, 14% tint via Denver pd. 57k on current engine.
  2. #2 Re: coolant issues
    Flush the coolant out those pills probably clogged something up. Or your LIM gasket is leaking.
  3. #3 Re: coolant issues
    Im with that guy.
    Flush the cooling system and bleed all the air out.
    Having a 180ยบ thermo wont stop the coolant from reaching 200+, if you idle in traffice the temps always rise and even going down the freeway it can still be in the 190's.
  4. #4 Re: coolant issues
    Lakewood,Co
    It was 104* yesterday yeah I'll flush it. Its 0325 and only 80* and never went higher than 181*
  5. #5 Re: coolant issues
    Exterior temp is likely why your temp was up. I see your in Colorado and likely in some climbing territory where the engine is going to work hard in that kind of heat. I'd flush it out, maybe replace the stat in case it got gunky then motor on.
  6. #6 Re: coolant issues
    Lakewood,Co
    Hahaha I do take her in the mountains on dirt roads. Check my pics on Facebook my name is Ryan volleberg the dirty engine pic is the old engine.
  7. #7 Re: coolant issues
    it's ok, I can usually figure out what's up just by reading the post.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    200 is almost natural, whenever its 90+ my GP always runs about 190-205ish
    If you start hitting the 230s like mine did a few days ago that's when you have a problem, a new water pump and alot of coolant later and mine is running nice again.
    Also one idea, add coolant in the radiator and and be sure to burp the system, a common problem with these cars is the low coolant sensor goin bad, but seeing as you didn't have a problem before I would just add the coolant.
  9. #9 Re: coolant issues
    detroit
    Quote Originally Posted by ryandale View Post
    Hi,
    i am the technical manager at Prestone. I agree with the guys, you should do a thorough flush. Remove the thermostat and replace the housing. Fill the system with water and a flushing agent, run the car for an hour, flush it, refill with water and run again for 10 minutes, drain and replace the t-stat, fill with 50/50 long life coolant.
    If it's really brown you either have air in the system (carefully bleed it when refilling) or you have the onset of electrolysis. Check every single ground cable on the car, making sure they are tight, clean and secure. You can check for electrolysis by using a voltmeter on the millivolt scale, stick the ground on the battery, positive in the coolant with engine running. It should be less than 2.5 millivolts, if higher, the system is eating itself from the inside and needs carefull flushing.
  10. #10 Re: coolant issues
    Jan 2012
    FT Campbell, KY
    Quote Originally Posted by motorking View Post
    Hi,
    Call me skeptical if you want to, but this is the internet. There're plenty of 12 y/o kids who think they're god's gift. Can you cite some credible sources? This is really good information, what with the definite DMM values being listed, but I want to see confirmation.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  11. #11 Re: coolant issues
    detroit
    Check me out if you like, I have thousands of technical posts on the internet. 35 tech videos here youtube.com/cadzillals6.
    ASE Master Tech for 35 years, information is straight from chemists in Prestone labs. My shops facebook page is motorking automotive. Your cooling system is like a battery, when the PH level becomes acidic and the mineral content is high, it will generate electricity just like a battery. The spec given is general, OE manuals expect you to maintain the cooling system so they do not cover electrolysis. Happy to answer any cooling system question.
  1. Strange Coolant issues
    By Talon62 in forum General Tech Discussion
    Last Post: 06-18-2012, 07:44 AM
  2. coolant issues
    By popeyenate in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2012, 07:55 PM
  3. Coolant issues
    By blackedoutpony in forum General Grand Prix Discussion
    Last Post: 12-27-2011, 09:26 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
