Thread: Coolant leaks
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Coolant leaks
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    I have a bad coolant sensor and it usually flashes. But as of today it just stays on. So I look at the temp.... And boy was I surprised! It was about 250 Degreesss!! So I shut the car off and went to the coolant... And it was green, not orange... Think I should drain it all and see if that stops the overheating? Or could there be more damage?
  2. #2 Re: Halp me
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    green is what u want it to be. that means its not dex-cool. unless it was orange, and turned green, in which case, i dont think thats possible lol. temp sensor is only 10-20$ its right on the lim right side. easy to replace.
  3. #3 Re: Halp me
    The low coolant light flashes?
    I would top off the coolant, and bleed the system of air, then be on your way.
    Mar 2012
    Minneapolis MN
    If I top it off it usually leaks out the overflow... And onto my PCM lol
  5. #5 Re: Halp me
    Minnesota
    Quote Originally Posted by Kolton Lock View Post
    So you have a hole in your coolant overflow? What year is your car?
    Mar 2012
    Minneapolis MN
    It's a 98, so the coolant reservoir is on the driver side of the car right next to the PCM
  7. #7 Re: Halp me
    You didn't really give us enough of the right info to help you.
    What light is flashing?
    Do you fill through the overflow or at the radiator cap?
    Have you ever bled the system?
    Why don't you regularly glance at your temp gauge?
    Were you sitting still or in traffic when you saw 250F?
    Were you using a digital gauge to read temperature or guesstimating based on the dash temp gauge?
    Do you have access to a scanner to read actual temp?
    Mar 2012
    Minneapolis MN
    The low coolant light usually always flashes
    I have never touched the coolant due to the fact that I bought the car in the winter
    I have never bled it no.
    I regularly do, and it is normally between 180-200
    I had just arrived at a friends house when I saw the 250
    I was guessing based on the dash temp
    I do not have ready access to a scanner, but I can get one easily enough
  9. #9 Re: Halp me
    Why do you say you never touch it and contradict what you've already said. Makes no sense dude. You either touched it or you didn't.
    The solution to your problem is to replace the item that is located between the driverside front seat and steering wheel. Fix that and you'll be all set.
  10. #10 Re: Halp me
    I think.
    In easy terms, Bill means to fix; you.
  11. #11 Re: Halp me
    Portland Oregon
    First thing i'd do is drain coolant, grab a new thermostat and pop that in. Refill and bleed the system and see if your issue comes back
    Mar 2012
    Minneapolis MN
    Sorry about that contradiction, on a few less than legal substances last night... I think I meant , I'd I were to top it off it would leak.
    Thanks Bill.
  13. #13 Re: Halp me
    IF YOU WERE TO TOP IT OFF WHERE???
    Seriously.. you need to put the crack pipe down before you post.
    Mar 2012
    Minneapolis MN
    Not that hardcore man lol
    I decided to do what you said OH4CompG
    Okay so I really went all out today and checked stuff out. I thoroughly examined all the hoses from the radiator.. And the bottom had a tiny hole so I replaced it, thought I drained everything but apparently not, so I took a shower in antifreeze. Anyways I dropped in a new hose, and thermostat (for Shets and Giggles mainly). As a final check I wanted to examine the Water Pump. I took off the belt and moved the W/P around there was about 1-2 cm of play left and right. (towards and away from the engine).
    Took the car out for a drive after refilling with coolant correctly at the radiator. I nestled around 190-210 degrees at the thermometer in the dash.
    I'm thinking I will need a water pump soon...
    Is that good enough info Bill?
  15. #15 Re: Halp me
    May 2012
    pensalvania
    are you saying that you can pull the water pump away from the engine?? or the pulley?? either way thats bad.
  16. #16 Re: Halp me
    yeah thats a water pump on its way out for sure. just a matter of time before it leaks.(if its not leaking now) thats how loose mine was and it was leaking.
    Mar 2012
    Minneapolis MN
    Yeah I can pull the W/P away from the engine, but surprisingly isnt leaking yet
  18. #18 Re: Halp me
    May 2012
    pensalvania
    yea, id definitly replace that thing then before it leaks, causing damage to ur engine from overheating.
  19. #19 Re: Halp me
    No worries Kolton, enjoy.
  20. #20 Re: Halp me
    Apr 2009
    Fort Worth TX
    I'm sure he meant 1-2mm of play...
  1. Halp Meh!
    By Confusingboat in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2011, 06:39 AM
