Thread: Coolant leaks
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41 Re: Coolant leaks
    your probably done already, but if you got a nice new gasket with the pump, use the new gasket dry, nothing else.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Yeah I'm done lol I followed a guy on YouTube. It was a paper gasket, he said with those, a thin layer of RTV doesn't hurt
    Mar 2012
    Minneapolis MN
    Done with that part, I need some help, one of the screws holding the little pulley cover on fell under the radiator D: any hope in getting it out?
  4. #44 Re: Coolant leaks
    if you dropped it dropped it straight down, it could be laying on the plastic splash shield. you just got to kinda feel around for it. if you lost it 3 out of 4 bolts will get you by till you fine a new one.
    Mar 2012
    Minneapolis MN
    It's on the metal brace directly under the radiator....
    I always drop 1 screw.... Gosh.
    Mar 2012
    Minneapolis MN
    Got it!
    Running much better, except for the fact that I still need about 3/4ths of a gallon of antifreeze before its drivable lol
  7. #47 Re: Coolant leaks
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    u can add just 3/4 gallons of water if its summer, and swap it b4 winter if ur tight on cash lol.
    Mar 2012
    Minneapolis MN
    Well now it is really all solved, I kept adding coolant to the radiator and wondering why it kept over flowing and my climate control was blowing no heat on max.
    But with use of the search function I solved it. Adding coolant to the area underneath the Thermostat. After you fill that, tighten everything up, and turn that bleeder up on top of the thermostat housing, and let it sputter and drip coolant until the flow is smooth and then tighten it back up. Go through the burping process in the radiator, when youre done Top off the radiator with the car off and you're good to go. (at least it works for me, may vary, I suck at explaining.
    Doing that made the heat blow super warm and the car wasn't exceeding the 200* range at all. Even a few days ago when it was 95+ my car was nice and less than 200*.
  9. #49 Re: Coolant leaks
    May 2012
    pensalvania
    yea, always make sure too bleed the cooling system. the air will never work itself completely out without bleeding, and it will cause nice overheating in the process..
  1. Halp Meh!
    By Confusingboat in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2011, 06:39 AM
