Thread: RE: Stalling @ startup (cold only)
Results 1 to 5 of 5
  1. #1 RE: Stalling @ startup (cold only)
    May 2011
    Illinois
    Hello all…
    I have small issue maybe someone can help with..
    2003 Grand Prix GT 90,000 mi. 3.8L (L36)
    On cold start: The motor nearly stalls and then picks itself back up. The RPM’s drops to about 400 -> 500 then jumps suddenly to normal warm up RPM (about 1200 to 1500). I’ve never noticed this before this week.
    I purchased: ScanXL Pro with GM enhanced plugin, performed a data record driving around for about 15 mi. I noticed from the data that the engine never went into “open loop” when cold (maybe 40 to 50 degree outside temp is warm for open loop? Maybe someone has some input on this?).
    Additionally, I’m reading only two “02” sensors, I though there were three on this car.
    I’m thinking one 02 sensor may be the culprit, it reads lean and rich then back to lean frequently.
    Thanks again in advance for any help on this.
    Regards/Marc
  2. #2 Re: Stalling @ startup (cold only)
    Marc,
    You only have two O2 sensors, you are seeing the correct number. The way you describe the B1 Sensor is it's normal operation. It should toggle rich/lean fairly quickly.
    On the cold starts, I'd pull the TB and clean it and the MAF/IAC. You'll be surprised how much that helps things.
  3. #3 Re: Stalling @ startup (cold only)
    May 2011
    Illinois
    Marc,
    BillBoost,
    Thanks much for the info, you cleared up my concerns about the 02 sensor... I'll go ahead and pull the Throttle Body clean the MAF/IAC as you recommend, I have read elsewhere this is recommended to clear up minor issues...
    Thanks again for your reply..
    Best regards/Marc
  4. #4 Re: Stalling @ startup (cold only)
    Pennsylvania
    At 90,000 miles... some other maintenance - new spark plugs, new intake air filer, new fuel filer.
  5. #5 Re: Stalling @ startup (cold only)
    Sep 2011
    MI
    My car does that from time to time... I know I have a bad MAF(too cheap to buy a new one), so like Bill said, get some MAF Sensor cleaner and clean it. Cleaning the throtlebody can also help with some ideling issues.
  1. Replies: 1
    Last Post: 02-08-2012, 10:09 PM
  2. Rough Cold Startup
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2010, 03:41 PM
  3. Trans is dead on cold startup
    By brand121 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2010, 03:45 PM
  4. Surging on cold startup / down on power
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-15-2010, 03:07 AM
  5. Intermittent stalling on startup, then fires right up on second try. Ideas?
    By ChvyTrcksFrdScks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 06:17 PM
