Thread: L67 coil mount/engine mount bracket (passenger side) on an L36
Results 1 to 7 of 7
  1. #1 L67 coil mount/engine mount bracket (passenger side) on an L36
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    On my 02', for the passenger side engine mount bracket/coil pack mount, it's 3 pieces. An aluminum piece that the dogbone slides into. A steel support piece that mounts to that and of course an aluminum piece that the coil pack mounts onto. Would this piece from an L67 replace all that without issue??? Here's a picture of the L67 piece, any help would be appreciated.
  2. #2 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    Yup, it bolts right on, just like your busted L36 bracket would.
    I've always been a fan of the L67 ones anyways...cast iron > aluminum mount wise. You'd just leave the supercharged idler pulleys off...looks like so...
  3. #3 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    Apr 2009
    Carlisle PA
    Thanks Nick, that is exactly what I needed to read/see...
  4. #4 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    No problem.
    My silver car actually had one on there when I bought it, so the P.O...probably got tired of swapping them...and I'm sure he did it more than once since the mounts I yanked out of the bottom of that car were beyond destroyed. That thing felt pretty solid with solid rubber motor/trans mounts, poly upper squares, stock DB bushings in the back, for the record.
  5. #5 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    I pulled mine off of a 97 intrigue. (L36)
  6. #6 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    No problem.
    We need bill to show us that video proving W body mounts will never be as good as H body.
  7. #7 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    Hockey puck awesomeness.
  1. Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
    By jkk9 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 06:40 PM
  2. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
