Thread: Car lopes and sometimes dies when gas cap is opened.
Results 1 to 10 of 10
  1. #1 Car lopes and sometimes dies when gas cap is opened.
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    99 Grand Prix SE 3.8 249,000 on the clock.
    Car will lope and hunt to find idle when gas cap is opened.
    I checked out the Evap solenoid and it is closing when the car is off. Have yet to replace it as i seen no need to. Anyone know what else to check under the hood to see what would be keeping the solenoid open?
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  2. #2 Re: Car lopes and sometimes dies when gas cap is opened.
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    What do you need to keep the gas cap off for when the cars on anyway lol
  3. #3 Re: Car lopes and sometimes dies when gas cap is opened.
    What happens when you remove the gas cap, does pressure go up or down?
    Isn't it tiring running next to the car to open the cap with it driving down the road?
    The cap technically shouldn't be getting removed with the car running because gas fumes plus spark equals undesirable result.
  4. #4 Re: Car lopes and sometimes dies when gas cap is opened.
    Dec 2011
    Cadiz, Ky
    Sounds stupid I know. But I guess theres times the gas cap did not seal 100% and has caused some Drive-ability and safety issues. Causing the engine to stall say in the middle of an intersection. Also after I refuel, I start it and it will stall. Repatedly until it builds up vacuum in the fuel tank. Unless i sit there and hold the throttle for a 10-15 seconds.
  5. #5 Re: Car lopes and sometimes dies when gas cap is opened.
    Vacuum or pressure? Why would vacuum in the tank cause it to start?
  6. #6 Re: Car lopes and sometimes dies when gas cap is opened.
    Dec 2011
    Cadiz, Ky
    Because the Evap solenoid is opening up, allowing basically a massive intake vacuum leak to open up from the fuel tank when cap is removed. Would a video of the issue help any? I can remove the gas cap with it running and it will lope and hunt and surge for idle, I put my hand over the gas filler and i can feel a vacuum, once it builds up the lope stops.
  7. #7 Re: Car lopes and sometimes dies when gas cap is opened.
    Dec 2011
    Cadiz, Ky
    It really becomes a ***** when its been sitting in the sun and i try to start it, And it wont start worth a ****. Have to sit there and race it for a while.
  8. #8 Re: Car lopes and sometimes dies when gas cap is opened.
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    if this is actually your problem why dont you replace your gas cap?
  9. #9 Re: Car lopes and sometimes dies when gas cap is opened.
    Sounds like you've hunted down the issue to be a major vacuum leak. Any codes from it? Take a look at the FSM and learn how this system works and that will tell you if there's something malfunctioning. Which will lead you to the correct part to replace.
  10. #10 Re: Car lopes and sometimes dies when gas cap is opened.
    Dec 2011
    Cadiz, Ky
    Quote Originally Posted by RyanL View Post
    Really wish it was that easy. The Evap solenoid is opening up full time when the ignition is turned ON. Allowing full manifold vacuum to be pulled on the fuel tank. Opening the fuel cap or expansion of fuel vapors from cold to hot creates a rush of air/fuel vapor into the manifold upon start up causing the car to die or lope. Thats the best way i can explain it.
  1. 98 Grand Prix GT 3800 159k on it but engine LOPES
    By Fritcr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2012, 11:53 AM
  2. SSIC core opened up; saw pics somewhere???
    By agrazela in forum General Tech Discussion
    Last Post: 08-13-2009, 08:06 AM
  3. I opened a new bank account
    Last Post: 04-05-2009, 11:05 AM
  4. Replies: 0
    Last Post: 03-24-2009, 03:09 PM
