Thread: Oil drain plug size
Results 1 to 4 of 4
  1. #1 Oil drain plug size
    New Jersey
    Dumb question,
    What size is the stock drain plug? I need to pickup a new wrench and can't remember what size I was missing. 13MM?
  2. #2 Re: Oil drain plug size
    15mm
  3. #3 Re: Oil drain plug size
    My dumb question back to you. What year do you drive?
    Typically a steel pan is 15mm and an aluminum pan is 13mm.
  4. #4 Re: Oil drain plug size
    New Jersey
    Wow I can't believe I didn't put the year I'm sorry. Another forum I frequent for a different vehicle has it on my signature.
    Its an 06 so aluminum pan.
    Thanks for the help I appreciate it.
  1. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  2. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  3. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  4. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
  5. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
