Thread: Comp Cams 1.9 Roller Rockers
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Comp Cams 1.9 Roller Rockers
    GTP Level Member apierce1289's Avatar
    United States
    Ok so I just bought a set of these rockers and I have a few questions. Right now I have SD headers, an Overkill pcm, no cat, and a performance cat back exhaust. With these comp cam 1.9 roller rockers what will I see for gains? And can I run my current pcm till I'm ready to tune?
    Sent from my XT912 using Tapatalk
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #2 Re: Comp Cams 1.9 Roller Rockers
    Minnesota
    You can run your current PCM file without a problem. The only thing is you might want to get someone to adjust your car to shift a little higher.
    I would get some springs and modified retainers along with new valve seals for when you put those rockers on though.
    United States
    What kinda springs would be good? Keep in mind I'm wanting to turbo later.
  4. #4 Re: Comp Cams 1.9 Roller Rockers
    Minnesota
    I used L92 springs but I am not sure with a turbo...Someone else might have to chime in on that.
  5. #5 Re: Comp Cams 1.9 Roller Rockers
    Northeast Ohio
    i hear ls6 90# springs would do good for now and when turboed
    United States
    Okay hopefully someone more knowledgeable can help out :-)
    United States
    Really none of you can help? What should I get for this install? I want top of the line parts so I can have piece of mind. And if possible the strongest parts that will compliment a turbo setup.
  8. #8 Re: Comp Cams 1.9 Roller Rockers
    Crow 105's.
    Get em.
  9. #9 Re: Comp Cams 1.9 Roller Rockers
    I've heard a lot of turbo guys say, 130# is the only way to go. I don't have actual experience and never looked into a turbo setup which is why I was being quiet.
  10. #10 Re: Comp Cams 1.9 Roller Rockers
    With 130's however they recommend a double roller.
    And you know how I feel about a double roller.
  11. #11 Re: Comp Cams 1.9 Roller Rockers
    Ohio
    105s with just the rockers..130s if you ever ditch those money pits and go cam
  12. #12 Re: Comp Cams 1.9 Roller Rockers
    I'm not saying the 130's don't need supporting mods. Just saying..i hear that a lot from Turb guys.
    United States
    I've heard that 1.9 can compliment a turbo setup very well. Cams are a big job and I also got these cause I got them used off a guy on here (very nice condition too) cheaper price. I don't have boat loads of cash.
    United States
    Will I hurt my car if I do 130's with what I have now?
  15. #15 Re: Comp Cams 1.9 Roller Rockers
    Ohio
    nooooo
  16. #16 Re: Comp Cams 1.9 Roller Rockers
    Ummm, pierce needs to research.
  17. #17 Re: Comp Cams 1.9 Roller Rockers
    You want enough to prevent float for the life of the spring, but not too much otherwise its unneeded stress on your timing/valvetrain/seats.
    United States
    Quote Originally Posted by 99pgpgt View Post
    nooooo
    No to benefiting a turbo setup? Or no the 130's won't hurt my car?
  19. #19 Re: Comp Cams 1.9 Roller Rockers
    Go with an LS6 if you don't want to change the timing chain. If you go turbo and get float, then change the springs and timing chain at that point.
    1.9's do compliment a turbo nicely. However to use them, you want springs, retainers, reusable bolts and valve seals.
  20. #20 Re: Comp Cams 1.9 Roller Rockers
    Ohio
    105s and you can stay on a stock replacement chain and dampener.
