I am stumped and need some help. The engine is a 2005 seriesIII. Iron head, block, and aluminum intake upper and lower. The following iswhat I know:
Taking in coolant
Losing oil. Doesshow a small external leak but not sure if it is leaking as much as it is losing.
No water incoolant
Compression checkshowed 100 Psi in # 4 cylinder
All others175-180
Spark plugin # 4 look just like the others.
Shows ahistory of a miss in # 4 but is not currently missing
Strongexhaust pulse out the oil fill tube
Oil in plenumto the point the air clean has oil on it. Not sure if this is due to an overoil file.
This is my thought, slow leak in cylinder head gasket. Washeddown cylinder walls and took out rings. The problem is, these motors are notknown for blowing head gaskets. Also, I would think the spark plug would showsome signs of oil or water consumption. I would also think that with the amountof exhaust that is in the rocker cover, if caused by blow by, there would alsobe water in the oil.
Any ideas would be appreciated.
Thanks,
