my engine started to knock after comming from work at first it was loosing power the rpms would go up and it would int advance at a stop the engine died I started and it kept knocking I check the oil because when I would press on the gas and on the dic it would read low oil pressure. I removed the belt and the knock its still there and the higher the rpm the louder it gets need help
